MIFARE Plus reader
MIFARE Plus reader
Serhii
I am developing a MIFARE Plus reader in SL3 mode and I am using the NFC Reader Library, but I can't find information on using the functions from this library in the docstore. I know that there is a description of this library for MIFARE Classic and MIFARE Ultralight (UM10663), is there the same document for MIFARE Plus?
Best regards.
Kan_Li
Hi @Viktor_ ,
Ds163735 is for Mifare Plus, not Mifare Plus EV2, so you don't have access to it. Please use the proper data sheet for the parts you select.
Kan
Viktor_
How can I receive access to documents of other Mifare Plus types (EV0, EV1)?
In "Access Rights" section on docstore I can request rights only to "MIFARE Plus EV2".
Kan_Li
Hi @Viktor_ ,
I am sorry, but you have to contact the docstore team for help with it. please send mail to [email protected] for further help.
Thanks for your patience and understanding!
Kan
Viktor_
Ok, thank you.
