How to reduce the power consumption in polling MFRC523 ?
935 次查看
waynechung1
I have some question in polling MFRC523.
I use 2 second timer polling mfrc523 to detect card, but the power consumption is not good.
How can I set this RFID chip ?
标记 (2)
877 次查看
Kan_Li
If you want to reduce the power consumption during polling, you may increase the antenna target impedance but that will decrease the performance(working range). so better use a RF chip supporting LPCD, such as CLRC663 plus.
Kan
