Matching circuit of the 30 x 50 mm antenna for PN5180, PN7462
jarojuda
Hello everybody,
where can I find the values of elements for the medium-size antenna included in the PNEV7462 and PNEV5180 kits?
IvanRuiz
You should measure the actual values of your antenna and select the correct values for the matching circuit.
Note: We will continue the support of the new request via case.
Thank you.
Ivan.
