Hardware reset for CLRC663
1,345 次查看
Danz1
May I know the maximum time interval that the IC will be ready after PDOWN transits from High to Low?
Thanks.
Rgds
Danz
1,328 次查看
KaiLi
Hello @Danz1
Thanks for contacting us and interested in the NXP products.
I also haven't been able to find any specific data for the time intervals, which would be hard to test out. But it shouldn't be very long, more than 10 microseconds should be fine.
Anyway, I'll consult with the R&D team for that. I'll keep update you if any news.
To update this case, you may reply by email.
To provide confidential information or attachments, you may add that online.
Please login to our NXP technical support portal:
https://support.nxp.com/s/case/5002p00002s3jrPAAQ
The portal allows access to the full details of the case, including the previous communication.
Thank you for your interest in NXP Semiconductor products and for the opportunity to serve you.
Kelly
Technical Support
NXP Semiconductor
