I'm trying to test PN7642A, but when I connected like the image below, it returned error "RESET (pin 15) high, but should be low. Please check target hardware".
I hope somebody of you can help me!
Thanks for your help.
I damaged the kit unwittingly. So, I've to wait for the repair.
I'll try your solution when it alright.
Mike.
Hi @MikeTaDien :
It seems a debug tool issue, one similar case discussed here.
https://forum.segger.com/index.php/Thread/1345-WARNING-RESET-pin-15-high-but-should-be-low/
can you use other debug tool such as MCU LINK PRO, or LPC-LINK2?
