CLRC663 plus with I2C interface
257 次查看
MartinHo
I need to used the CLRC66303HN with the I2C interface.
Is there an example how to convert the NxpNfcRdLib_RC663 to use the I2C?
The DAL seems to support only the SPI interface.
标记 (1)
201 次查看
jimmychan
Unfortunately, there is no I2C based example.
Solved: CLRC663/610 and i2c communication examples - NXP Community
194 次查看
MartinHo
A little bit disappointing, that You promote a Component with I2C and do not deliver a possibility to us this interface.
I will try to open a case.
Martin
