2395024_en-US
2395024_en-US
2395024_en-US
Support Required: Wayland-EGL Plugin and Video Playback Performance Issue with IVI-Shell
Hi NXP Team,
We need your support regarding a Wayland/Weston shell-related issue observed in our Yocto Linux setup.
We are currently validating video playback with kiosk-shell and ivi-shell. With kiosk-shell, the wayland-egl plugin is detected and accessible, and video playback is working smoothly without frame drops or system hang. However, with ivi-shell, we are not able to access/get the wayland-egl plugin properly, and video playback is showing frame loss and intermittent hang.
Please find the issue summary below:
Item Observation
Platformi.MX8QXP C0 MEK
OSYocto Linux [ Scarthgap L6.6.5]
Weston Shell 1kiosk-shell
Weston Shell 2ivi-shell
Graphics InterfaceWayland / Wayland-EGL
Video PlaybackGStreamer-based playback
Observation
Test Case Result
kiosk-shell + wayland-eglPlugin is available and accessible
kiosk-shell + video playbackVideo plays smoothly without frame loss or hang
ivi-shell + wayland-eglwayland-egl plugin is not getting detected/accessed properly
ivi-shell + video playbackFrame drops and intermittent hang observed
Support Required
Could you please help us with the below points?
  1. Is wayland-egl fully supported with ivi-shell on i.MX8QXP Yocto Linux 6.6.5 version
  2. Are there any specific Weston, IVI-shell, or compositor configuration changes required to enable wayland-egl with ivi-shell?
  3. Is there any recommended weston.ini configuration for ivi-shell on i.MX8QXP?
  4. Are there any known limitations with ivi-shell for video playback or GPU-accelerated rendering?
  5. Is there any reference document, patch, or example application available for ivi-shell + wayland-egl + video playback?
  6. Could the frame loss/hang be related to compositor configuration, buffer handling, GPU/VPU integration, or GStreamer sink selection?
Request
Please provide your guidance, recommended configuration, and any available reference documents or patches to resolve this issue.
Re: Support Required: Wayland-EGL Plugin and Video Playback Performance Issue with IVI-Shell
You may refer to the following documentation:
https://wayland.pages.freedesktop.org/weston/toc/ivi-shell.html
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/AGL-architecture-and-How-to-port-in-i-MX...
Best regards/Saludos,
Aldo.
No ratings
Version history
Last update:
‎07-17-2026 02:32 AM
Updated by:
