The prompt appears after I finish configuring the CAN Communication: “The plugin configuration dialog failed. Try to specify the connect string manually.”
until this issue is solved, please see a workaround discussed here.
Michal
Hello the version 3.2.7 has been released. This version fixes the CAN plug-in dependency issue discussed in this thread.
Michal
