Dear sir,
I want to use Trace32 to debug the S32K388. I followed the link below to install the Trace32 plug-in:
After that, I created new projects using the Trace32 debug configuration—both single-core and multi-core projects.
However, when I try to debug with Trace32, I always get error messages.
Also, when debugging multiple cores, I encounter an issue where the M7_1_0.elf and M7_2_0.elf cannot be programmed.
Could you please help test this?
Thanks.
BR,
Sean Wu
I am not sure how it works dirrectly from S32DS as I was not able to get it working.
But I never used S32DS to start Trace32 powerview,
Simply start the powerview from T32 folder and then execute programming script from menu.
Here you will find programming script. Just execute it in Powerview and program the device.
I will check meantime if I can get it up and running trough S32DS.
Peter
Hi petervlna,
Could you please share the s32k38x.cmm to and the s32k38x.bin(maybe this name in your folder) to me? I don't have this file.
Thanks.
BR,
Sean Wu
I have send them to you via private message.
Peter
Dear petervlna,
I use your s32k38x.cmm, and it works well. Thanks for your help.
BR,
Sean Wu
