KW47— Datasheet suggest the value of DCDC capacitor (Cout) is 22uf and must not exceed the min(6uf)/max (30uf)value.But we found NXP‘s SCH like SPF-91101_C use 1μf instead. KW45‘s SCH use the same value 22uf with datasheet.
So Which value should we use ?
Please help us check the following
The best way to build a PCB first time right with KW47 (Automotive) or MCX W72 (IoT/Industrial)
Any question , let us know
Hello @nicosuki , hope you are doing well.
I apologize for the inconveniences, but as this device has not been officially launched, most of the information about this product is still under NDA. The information available is the one mentioned previously on: The best way to build a PCB first time right with KW47 (Automotive) or MCX W72 (IoT/Industrial)
Could you please contact the person who helped you get the documentation in the first place?
Ana Sofia.
