For a safety critical application we'd like to use the certified ARM Clang compiler. Are there any issues I should be aware of when using this with Design Studio?
Can someone point me to an integration guide for using another compiler?
Thank you and best regards,
Kenny
Clang compiler is not officially supported, we do not have experience with this compiler. I can see that eclipse plugin should exist, so you can try to follow this HOWTO document for GHS compiler, it should be similar:
Lukas
