Hello @XH !
From what I can see from the attached screenshot, it seems that the model you are trying to build is placed at a wrong path (C:\Users).
It is very likely that you(or MATLAB) do(does) not have the correct privileges/write access in C:\Users. Please try to move the model at the path where your MATLAB projects are stored and re-build from there. Or if you did not make any changes to the model, you can try to build it directly from the Examples folder of the toolbox.
Florin.
