configure CAN to send different IDs
MaMM
Hi.
I'm trying to send different IDs thorugh the same CAN PORT in simulink (s32k39 board), and I cannot find how to assign different buffers to each ID. If I use the same configuration for different IDs thorugh CAN, I can read the messages but at double rate of the frequency I have selected.
For example, if I configure 100ms as base task time, and I add two simulink blocks to send CAN Messages, I can see on the USB to CAN tool both message but at 200 ms. If I use only one sending block, I can see 1 message at 100ms, so I suppose that another can_buffer must be used, but I cannot find where to change it.
An example of a .mdl with several ID configured thorugh the same port will be appreciatted.
Miguel.
Adrian_Gherca
Here are two methods to send out CAN messages with multiple IDs using the MBDT blocks:
First method:
1) In your configuration project (S32 Configuration Tool or EB tresos), under Can_43_FLEXCAN\CanConfigSet\CanHardwareObject, increase the value of Can Hw Object Count to the desired number of Tx messages:
2) In the Simulink model add the same number of Can_Write blocks, each block with a different value for the Pdu ID input:
Second method:
1) Make sure that multiple TRANSMIT objects exist in the configuration project under Can_43_FLEXCAN\CanConfigSet\CanHardwareObject. If necessary, press the "+" symbol and create more at the end of the list:
2) Select a different Hardware Object for each one of the Can_Write blocks:
MaMM
Thanks a lot. Both solutions work perfectly.
Miguel.
Adrian_Gherca
First method:
Second method:
%3CLINGO-SUB%20id%3D%22lingo-sub-2030647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Econfigure%20CAN%20to%20send%20different%20IDs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2030647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi.%3C%2FP%3E%3CP%3EI'm%20trying%20to%20send%20different%20IDs%20thorugh%20the%20same%20CAN%20PORT%20in%20simulink%20(s32k39%20board)%2C%20and%20I%20cannot%20find%20how%20to%20assign%20different%20buffers%20to%20each%20ID.%20If%20I%20use%20the%20same%20configuration%20for%20different%20IDs%20thorugh%20CAN%2C%20I%20can%20read%20the%20messages%20but%20at%20double%20rate%20of%20the%20frequency%20I%20have%20selected.%3C%2FP%3E%3CP%3EFor%20example%2C%20if%20I%20configure%20100ms%20as%20base%20task%20time%2C%20and%20I%20add%20two%20simulink%20blocks%20to%20send%20CAN%20Messages%2C%20I%20can%20see%20on%20the%20USB%20to%20CAN%20tool%20both%20message%20but%20at%20200%20ms.%20If%20I%20use%20only%20one%20sending%20block%2C%20I%20can%20see%201%20message%20at%20100ms%2C%20so%20I%20suppose%20that%20another%20can_buffer%20must%20be%20used%2C%20but%20I%20cannot%20find%20where%20to%20change%20it.%3C%2FP%3E%3CP%3EAn%20example%20of%20a%20.mdl%20with%20several%20ID%20configured%20thorugh%20the%20same%20port%20will%20be%20appreciatted.%3C%2FP%3E%3CP%3EMiguel.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2031277%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20configure%20CAN%20to%20send%20different%20IDs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2031277%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20a%20lot.%20Both%20solutions%20work%20perfectly.%3C%2FP%3E%3CP%3EMiguel.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2030787%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20configure%20CAN%20to%20send%20different%20IDs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2030787%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3EHere%20are%20two%20methods%20to%20send%20out%20CAN%20messages%20with%20multiple%20IDs%20using%20the%20MBDT%20blocks%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3EFirst%20method%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E1)%20In%20your%20configuration%20project%20(S32%20Configuration%20Tool%20or%20EB%20tresos)%2C%20under%20Can_43_FLEXCAN%5CCanConfigSet%5CCanHardwareObject%2C%20increase%20the%20value%20of%20Can%20Hw%20Object%20Count%20to%20the%20desired%20number%20of%20Tx%20messages%3A%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Adrian_Gherca_2-1737387835414.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Adrian_Gherca_2-1737387835414.png%22%20style%3D%22width%3A%20348px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F320403i5EABC2DD4301253E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Adrian_Gherca_2-1737387835414.png%22%20alt%3D%22Adrian_Gherca_2-1737387835414.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2)%20In%20the%20Simulink%20model%20add%20the%20same%20number%20of%20Can_Write%20blocks%2C%20each%20block%20with%20a%20different%20value%20for%20the%20Pdu%20ID%20input%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Adrian_Gherca_3-1737388017462.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Adrian_Gherca_3-1737388017462.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F320405iE9B8A24E73F91371%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Adrian_Gherca_3-1737388017462.png%22%20alt%3D%22Adrian_Gherca_3-1737388017462.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ESecond%20method%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E1)%20Make%20sure%20that%20multiple%20TRANSMIT%20objects%20exist%20in%20the%20configuration%20project%20under%20Can_43_FLEXCAN%5CCanConfigSet%5CCanHardwareObject.%20If%20necessary%2C%20press%20the%20%22%2B%22%20symbol%20and%20create%20more%20at%20the%20end%20of%20the%20list%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Adrian_Gherca_6-1737388568483.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Adrian_Gherca_6-1737388568483.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F320409i7C19BD4D735F7CDC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Adrian_Gherca_6-1737388568483.png%22%20alt%3D%22Adrian_Gherca_6-1737388568483.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2)%20Select%20a%20different%20Hardware%20Object%20for%20each%20one%20of%20the%20Can_Write%20blocks%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Adrian_Gherca_7-1737390660109.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Adrian_Gherca_7-1737390660109.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F320412iD9BC626CFEBA3E36%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Adrian_Gherca_7-1737390660109.png%22%20alt%3D%22Adrian_Gherca_7-1737390660109.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3E%3CIMG%20border%3D%220%22%20alt%3D%22%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20id%3D%22tinyMceEditorAdrian_Gherca_1%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20id%3D%22tinyMceEditorAdrian_Gherca_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E
