Try to flash our own algorithm to s32k144EVB
5,046 次查看
shukla007
In image1 I am try to flash our BMS algorithm but its show error I take the reference Nxp BMS example that is in image 2 can you help me how i can flash our bms algorithm
To flash our algorithm what change required to my algorithm can you tell me
5,024 次查看
mariuslucianand
Hello @shukla007,
The level of detail regarding the errors you are facing you have provided in this post is too low so we could suggest any solution for your encountered issue. From the screenshot, I can see that Simulink has detected a couple of issues. My suggestion is to press on the "View 60 errors" button, and try to address each of the mentioned errors.  A possible cause is that the output data type from the BCC Get_Values block might be mismatched with the inputs of your algorithm.
Hope this helps,
Marius
4,995 次查看
shukla007
As you give the above solution I am able to solve error but I am unable to solve one error can you help me to solve that error so I can genrate the code and flash it into the s32k144 board I put a screenshot of that error
标记 (1)
