no Library was found in the Library Browser of simulink
已解决
跳至解决方案
1,827 次查看
yebing
HI,experts:
After installing the NXP Support Package, no Library of the associated nxp was found in the Library Browser of simulink.As follows:
标签 (1)
标记 (2)
1 解答
1,802 次查看
Irina_Costachescu
Hi @yebing
Could you please take a look at the following post addressing the same issue? https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/MPC57xx-MBDtoolbox-not-appears-in-Simul...
I think the solution provided here could help you as well.
Irina
在原帖中查看解决方案
2 回复数
1,803 次查看
Irina_Costachescu
Hi @yebing
Irina
1,778 次查看
yebing
Hi,Irina:
Thank you very much for your patient reply! Following your instructions, I solved the problem.
