The configuration of PWMX[n]
1,719件の閲覧回数
hjhjhj
Hi Daniel,
     It's easy to configure DutyCycle for PWMA[n] and PWMB[n],but as for the PWMX[n],it seems that there's no way to configure DutyCycle for PWMX[n].Do you know any way to solve it?
Thank you!
HJ
Original Attachment has been moved to: TEST101010.slx.zip
4 返答(返信)
1,436件の閲覧回数
hjhjhj
Hi Daniel,
     Is there any solution to the problem?
Thank you!
HJ
1,437件の閲覧回数
Daniel_Popa
Hi hjhjhj‌,
Sorry for delay.
I've not finalized the investigation yet. Due to the age of this toolbox i need to understand the reasons behind that decision. So far i checked the code and the PWMx duty cycle is not supported therefore it can(sorry for typo) cannot be enabled
As soon as i have a final conclusion (please give me 2 days) i'll reply here.
Thank you!
1,437件の閲覧回数
hjhjhj
Hi Daniel,
     Is there any progress in this problem?
Thank you!
HJ
1,437件の閲覧回数
Daniel_Popa
Hi hjhjhj‌,
Unfortunately, i have bad news. The PWMX functionality is not supported. What you see in the UI is a mistake - failed to remove the selection for the the Output Signals panels. I checked the code and there is no place where that control is used.
Since there is nothing to fix - the functionality is missing all together - this is not a candidate for a patch.
