The LoadPull results from ADS are different from the datasheet.
1,426件の閲覧回数
3109851909
Hello All:
              I want to design a Power Amplifier using MRF6S21050L. Firstly, I simulated in the software ADS. To get the optimum Sourceimpedence  and Loadimpedence, I used the tool-- LoadPull in ADS. However, the results of simulation in ADS are different from the datasheet. This question had puzzled me a long time. So I simulated some other LDMOS of NXP in ADS using Loadpull. I found the results are always different from the datasheet. Have you ever met this case? Could you give me some help to solve the problem?
Thanks all,
Xiong
1,369件の閲覧回数
mariuslucianand
Hello  得安 熊,
This community space does not cover the topic you need assistance on. Please create a new thread on the Power Management space or new NXP support case according to the following procedure: https://community.nxp.com/docs/DOC-329745
Hope this helps,
Marius
