S32K144 Model based design
2,107件の閲覧回数
Sriram
Hello ,
I am trying to interface the sine cosine encoder in my motor with the s32k control board to measure the rotor position. I tried commenting out the hall sensor adc blocks and assigned 2 adcs for the sine cosine encoder. But i cant see the sine cosine outputs in freemaster as the  variables are not showing up.
I have attached the slx file of the model .
Can anyone check whether my model is correct or should i change anything in it to see the sine cosine encoder output in freemaster.
Thank you
#S32k144 S32K144 Model based design
タグ(1)
1,998件の閲覧回数
brianmckay
Did you check out the Community site? Has lots of info and links for S32K144.
https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/S32K-How-To/m-p/719984
Cheers,
-Brian
