RF Power Field Effect Transistor Non-linear Model
2,936 次查看
andrewbarinov
I'm using RF transistor MRF6V10010N at frequncies between 960-1250Mhz. In order to simulate matching network and evaluate transistor gain, using AWR Microwave Office, I need wide band parameters of this transistor. Unfortunately, there is no nonlinear data library (AWR Model KIT) for this Transistor on your website. Is it possible to get it somehow? I have downloaded MRF6V10010N Datasheet, but there is no suitable transistor parameters there.
Andrew
4 回复数
2,834 次查看
Daniel_Popa
Hi Andrew,
Unfortunately, this community does not covers such topics. We are only focused on topics related with MATLAB/Simulink code-generation and simulation for NXP microprocessors.
My suggestion is to go via Support Request option on Support|NXP page. This way your request will be routed to the appropriate team inside NXP.
Hope this will help you!
Thank you!
2,834 次查看
andrewbarinov
Thank you Daniel,
Bit I don't even understand, where to write my question. On the link you suggested there are:  technical communities, Chat, Support Requests and Additional Support. I suppose I should write to the last section (NXP Approved Engineering Consultants), but i cant find out where to describe my problem inside the section.
Thank you,
Andrew
2,834 次查看
Daniel_Popa
Hi Andrew,
You'll need to click here:
or use this direct link: https://nxpcommunity.force.com/community/
Then you will need to fill a new case:
This way your question will be routed via TIC internal NXP support engineers.
Hope this helps!
2,834 次查看
andrewbarinov
Thank you so much, Daniel!
I have sent my request due to this form. Waiting for any answer...
Andrew
