Pwm_delay_in_trigger_pulse
Vijay98
Hello NXP team,
Currently we are generating the pwm pulse for two channels.
and with pwm channel 1 pulse, we are triggering the pwm channel 2 pulse with edge triggering.
but with triggering, there is some delay in Pwm channel 2 pulse and that delay is not constant it is getting varying from one pulse to another pulse.
Photo - 1: 820uS delay for pwm 2.
Photo - 2: no delay for pwm 2.
Photo - 3: 520uS delay for pwm 2.
we don't know how to reduce this delay, and it is not constant delay.
We have attached the configuration settings for this pwm pulse below,
Emios_0 - Channel_0 for pwm2 pulse
Emios_1 - Channel_0 for pwm1 pulse
Mcl_configuration for Pwm2 pulse
Kindly help us to resolve this issue related to pwm delay.
Thanks, and regards,
Esakki.P
@Irina_Costachescu @dragostoma
@DrKarthi
stefanvlad
Hi @Vijay98 ,
I'm not sure what do you mean having an issue on PTC10, since on this thread  Re: Pwm_delay_in_trigger_pulse - NXP Community, the solution works well and tested on logic analyzer.
Can you provide pictures of the model that you modified based on the steps i provided in the thread above, instead of reposting my screenshots.
Once again to use another pin to output the signal from PTA3 to PTC10 there are only two options, one is presented above by using PTC10 as emios_0_ch6 and the other solution is to use PTC10 as lcu1_out11:
Then you need to route the signal from PTA3 (lcu0_out2) to PTC10 (lcu1_out11) using TRGMUX:
Then we need to update the LCU configuration for the new input:
And then we update the LCU output config:
Also PTC10 pin needs to be added into the Port peripheral:
and the last step is to update the model with the new LCU output:
After this, clean up the local Matlab folder, delete the .slxc file, and the folders 32k312_pwm_lcu_mod_carrier_s32ct_ert_rtw, and slprj:
Then rebuild and flash the project on the S32K312 board, and check the pins with logic analyzer:
And to summarize the complete application, how all the peripherals are connected, I have created this diagram:
This are all the steps needed, please read them carefully and replicate them on your model,
Stefan V.
DrKarthi
@stefanvlad
kindly update the solution for above issue.
or it will be helpful if we discuss in a teams call.
%3CLINGO-SUB%20id%3D%22lingo-sub-1955433%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1955433%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20NXP%20team%2C%3C%2FP%3E%3CP%3ECurrently%20we%20are%20generating%20the%20pwm%20pulse%20for%20two%20channels.%3C%2FP%3E%3CP%3Eand%20with%20pwm%20channel%201%20pulse%2C%20we%20are%20triggering%20the%20pwm%20channel%202%20pulse%20with%20edge%20triggering.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_0-1726550630893.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_0-1726550630893.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299358i4DD3C0F321532759%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_0-1726550630893.jpeg%22%20alt%3D%22Esakki_0-1726550630893.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Ebut%20with%20triggering%2C%20there%20is%20some%20delay%20in%20Pwm%20channel%202%20pulse%20and%20that%20delay%20is%20not%20constant%20it%20is%20getting%20varying%20from%20one%20pulse%20to%20another%20pulse.%3C%2FP%3E%3CP%3EPhoto%20-%201%3A%20820uS%20delay%20for%20pwm%202.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_4-1726551336086.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_4-1726551336086.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299363iFC7DEF99CAF2E802%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_4-1726551336086.png%22%20alt%3D%22Esakki_4-1726551336086.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EPhoto%20-%202%3A%20no%20delay%20for%20pwm%202.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_5-1726551406656.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_5-1726551406656.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299364i210F73BAC85C3CD4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_5-1726551406656.png%22%20alt%3D%22Esakki_5-1726551406656.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EPhoto%20-%203%3A%20520uS%20delay%20for%20pwm%202.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_6-1726551459604.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_6-1726551459604.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299365i60BA235E4F4B8283%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_6-1726551459604.png%22%20alt%3D%22Esakki_6-1726551459604.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Ewe%20don't%20know%20how%20to%20reduce%20this%20delay%2C%20and%20it%20is%20not%20constant%20delay.%3C%2FP%3E%3CP%3EWe%20have%20attached%20the%20configuration%20settings%20for%20this%20pwm%20pulse%20below%2C%3C%2FP%3E%3CP%3EEmios_0%20-%20Channel_0%20for%20pwm2%20pulse%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_7-1726551591729.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_7-1726551591729.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299367iF9DE6EC3CA19C733%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_7-1726551591729.png%22%20alt%3D%22Esakki_7-1726551591729.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_9-1726551786268.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_9-1726551786268.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299369iEF3A59B0468B8652%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_9-1726551786268.png%22%20alt%3D%22Esakki_9-1726551786268.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EEmios_1%20-%20Channel_0%20for%20pwm1%20pulse%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_8-1726551759125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_8-1726551759125.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299368i767C084A1D337CF5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_8-1726551759125.png%22%20alt%3D%22Esakki_8-1726551759125.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_10-1726551802652.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_10-1726551802652.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299370i885BE0BAD6B2C6EC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_10-1726551802652.png%22%20alt%3D%22Esakki_10-1726551802652.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMcl_configuration%20for%20Pwm2%20pulse%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_11-1726551854311.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_11-1726551854311.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299371i0DE1B1B62703EBBE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_11-1726551854311.png%22%20alt%3D%22Esakki_11-1726551854311.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EKindly%20help%20us%20to%20resolve%20this%20issue%20related%20to%20pwm%20delay.%3C%2FP%3E%3CP%3EThanks%2C%20and%20regards%2C%3C%2FP%3E%3CP%3EEsakki.P%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F100054%22%20target%3D%22_blank%22%3E%40Irina_Costachescu%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F199423%22%20target%3D%22_blank%22%3E%40dragostoma%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229388%22%20target%3D%22_blank%22%3E%40DrKarthi%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2013291%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2013291%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20for%20the%20reply.%3C%2FP%3E%3CP%3Eit%20helped%20us%20to%20understand%20the%20configuration%20very%20much.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2012221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2012221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI'm%20not%20sure%20what%20do%20you%20mean%20having%20an%20issue%20on%20PTC10%2C%20since%20on%20this%20thread%26nbsp%3B%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FPwm-delay-in-trigger-pulse%2Fm-p%2F2003791%2Fhighlight%2Ftrue%23M9822%22%20target%3D%22_blank%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%20-%20NXP%20Community%3C%2FA%3E%2C%20the%20solution%20works%20well%20and%20tested%20on%20logic%20analyzer.%3C%2FP%3E%0A%3CP%3ECan%20you%20provide%20pictures%20of%20the%20model%20that%20you%20modified%20based%20on%20the%20steps%20i%20provided%20in%20the%20thread%20above%2C%20instead%20of%20reposting%20my%20screenshots.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EOnce%20again%20to%20use%20another%20pin%20to%20output%20the%20signal%20from%20%3CSTRONG%3EPTA3%3C%2FSTRONG%3E%20to%20%3CSTRONG%3EPTC10%20%3C%2FSTRONG%3Ethere%20are%20only%20two%20options%2C%20one%20is%20presented%20above%20by%20using%20%3CSTRONG%3EPTC10%3C%2FSTRONG%3E%20as%26nbsp%3B%3CSTRONG%3Eemios_0_ch6%20%3C%2FSTRONG%3Eand%20the%20other%20solution%20is%20to%20use%20%3CSTRONG%3EPTC10%3C%2FSTRONG%3E%20as%26nbsp%3B%3CSTRONG%3Elcu1_out11%3C%2FSTRONG%3E%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1733937742783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1733937742783.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315421iF5E81811ED866B7E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1733937742783.png%22%20alt%3D%22stefanvlad_0-1733937742783.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThen%20you%20need%20to%20route%20the%20signal%20from%20%3CSTRONG%3EPTA3%20(lcu0_out2)%3C%2FSTRONG%3E%20to%20%3CSTRONG%3EPTC10%26nbsp%3B%3C%2FSTRONG%3E%3CSTRONG%3E(lcu1_out11)%26nbsp%3B%3C%2FSTRONG%3Eusing%20TRGMUX%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_1-1733937895546.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_1-1733937895546.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315422iF5A2D2E323BCEE82%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_1-1733937895546.png%22%20alt%3D%22stefanvlad_1-1733937895546.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThen%20we%20need%20to%20update%20the%20LCU%20configuration%20for%20the%20new%20input%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1733937955577.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1733937955577.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315423i38AA9DEA13321717%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1733937955577.png%22%20alt%3D%22stefanvlad_2-1733937955577.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EAnd%20then%20we%20update%20the%20LCU%20output%20config%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_3-1733938011056.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1733938011056.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315424i631F684F6030B030%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_3-1733938011056.png%22%20alt%3D%22stefanvlad_3-1733938011056.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EAlso%20%3CSTRONG%3EPTC10%3C%2FSTRONG%3E%20pin%20needs%20to%20be%20added%20into%20the%20Port%20peripheral%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_4-1733938099707.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1733938099707.png%22%20style%3D%22width%3A%20898px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315425i95BF54EA5AB8F412%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_4-1733938099707.png%22%20alt%3D%22stefanvlad_4-1733938099707.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Eand%20the%20last%20step%20is%20to%20update%20the%20model%20with%20the%20new%20LCU%20output%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_5-1733938321744.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1733938321744.png%22%20style%3D%22width%3A%20929px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315426i431C5AFF7CF27EB2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_5-1733938321744.png%22%20alt%3D%22stefanvlad_5-1733938321744.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EAfter%20this%2C%20clean%20up%20the%20local%20Matlab%20folder%2C%20delete%20the%20%3CSTRONG%3E.slxc%3C%2FSTRONG%3E%20file%2C%20and%20the%20folders%20%3CSTRONG%3E32k312_pwm_lcu_mod_carrier_s32ct_ert_rtw%2C%26nbsp%3B%3C%2FSTRONG%3Eand%26nbsp%3B%3CSTRONG%20style%3D%22font-family%3A%20inherit%3B%22%3Eslprj%3C%2FSTRONG%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_6-1733939601313.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1733939601313.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315429iAB36FFB7BD28FD79%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_6-1733939601313.png%22%20alt%3D%22stefanvlad_6-1733939601313.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThen%20rebuild%20and%20flash%20the%20project%20on%20the%20S32K312%20board%2C%20and%20check%20the%20pins%20with%20logic%20analyzer%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_7-1733939679624.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_7-1733939679624.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315430iDA7A3769CF6E6ECD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_7-1733939679624.png%22%20alt%3D%22stefanvlad_7-1733939679624.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EAnd%20to%20summarize%20the%20complete%20application%2C%20how%20all%20the%20peripherals%20are%20connected%2C%20I%20have%20created%20this%20diagram%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22s32k312_pwm_lcu_mod_carrier_s32ct.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22s32k312_pwm_lcu_mod_carrier_s32ct.png%22%20style%3D%22width%3A%20931px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315623i49FFE3875E0D6DD3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22s32k312_pwm_lcu_mod_carrier_s32ct.png%22%20alt%3D%22s32k312_pwm_lcu_mod_carrier_s32ct.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThis%20are%20all%20the%20steps%20needed%2C%20please%20read%20them%20carefully%20and%20replicate%20them%20on%20your%20model%2C%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2011000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2011000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThanks%20for%20the%20update%20and%20we%20have%20checked%20with%20that%20configuration.%3C%2FP%3E%3CP%3E1.%20With%20fast%20update%20method%20that%20you%20provided%20is%20that%20%3CSTRONG%3Ewe%20have%20an%20issue%20in%20generating%20low%20side%20pulse%20in%20PTC10%20pin.%26nbsp%3B%3C%2FSTRONG%3EKindly%20check%20the%20video%20uploaded%20with%20this%20post.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_2-1733827424686.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_2-1733827424686.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315062i835256416F9BF2F8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_2-1733827424686.png%22%20alt%3D%22Vijay98_2-1733827424686.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%20That%20%3CSTRONG%3Ewe%20have%20a%20low%20side%20pulse%20already%20generated%20in%20PTA3%20pin%20and%20we%20have%20to%20change%20that%20output%20to%20PTC10%20pin%20(low%20side%20pulse).%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_1-1733827048319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_1-1733827048319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F315060iD3DC3B3550DF2F5B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_1-1733827048319.png%22%20alt%3D%22Vijay98_1-1733827048319.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EFor%20that%20we%20need%20help%20with%20configuration%20to%20generate%20the%20low%20side%20pulse%20in%20PTC10%20pin.%3C%2FP%3E%3CP%3EKindly%20help%20us%20with%20this%2C%3C%2FP%3E%3CP%3EThanks%20%26amp%3B%20regards%2C%3C%2FP%3E%3CP%3EVijay%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2010344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2010344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ECan%20you%20repost%20the%20images%3F%20since%20they%20are%20very%20low%20resolution%20and%20cannot%20be%20read%20properly.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegarding%20the%20PTC10%20output%2C%26nbsp%3BI%20have%20already%20given%20the%20solution%20and%20required%20steps%20in%20this%20post%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FPwm-delay-in-trigger-pulse%2Fm-p%2F2003791%2Fhighlight%2Ftrue%23M9822%22%20target%3D%22_blank%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20am%20able%20to%20generate%20the%20%3CSTRONG%3EPWM_Modulator%3C%2FSTRONG%3E%20frequency%20of%201000Hz%20(1kHz)%20using%20the%20%3CSTRONG%3EPeriod%3C%2FSTRONG%3E%20%3D%20%3CSTRONG%3E7270%20%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1733763433340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1733763433340.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F314885i966A46AF12696787%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1733763433340.png%22%20alt%3D%22stefanvlad_0-1733763433340.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EAnd%20for%20%3CSTRONG%3EPeriod%3C%2FSTRONG%3E%20%3D%20%3CSTRONG%3E43500%3C%2FSTRONG%3E%20i%20was%20able%20to%20get%26nbsp%3B%3CSTRONG%3EPWM_Modulator%3C%2FSTRONG%3E%20frequency%20to%20167Hz%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_1-1733763983268.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_1-1733763983268.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F314887iCB7EA1F0A6629A71%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_1-1733763983268.png%22%20alt%3D%22stefanvlad_1-1733763983268.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBut%20for%20even%20lower%20frequency%20you%20need%20to%20modify%20the%20PWM%20configuration%20for%20both%20PWM%20channels%20in%20order%20to%20keep%20that%2011x%20times%20frequency%20in%20between%20them.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2009083%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2009083%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20nxp%20%2C%3C%2FP%3E%3CP%3EAny%20update%20on%20this%20Lcu%20pin%20configuration%26nbsp%3B%3C%2FP%3E%3CP%3EKindly%20help%20us%20on%20this%20issue%26nbsp%3B%3C%2FP%3E%3CP%3EThanks%20%26amp%3B%20regards%2C%3C%2FP%3E%3CP%3EVijay%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2006599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2006599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20support.%3C%2FP%3E%3CP%3EBut%20in%20fast%20update%20method%2C%20when%20we%20give%20our%20period%20and%20duty%20cycle%20value%20to%20generate%20pwm%20signal%20the%20output%20signal%20is%20much%20different%20from%20what%20we%20expected.%3C%2FP%3E%3CP%3EFor%20example%2C%3C%2FP%3E%3CP%3E1.%20I%20want%20to%20generate%20pwm%20pulse%20for%20frequency%20-%20%3CSTRONG%3E25%20Hz%20%3C%2FSTRONG%3Efor%20that%20%3CSTRONG%3Eperiod%20value%20is%201176%20(Core%20clock%20-%20120MHz%2C%20Clock%20divider%20value%20is%20255%20and%20internal%20prescalar%20value%20is%2016)%26nbsp%3B%3C%2FSTRONG%3Eand%20%3CSTRONG%3EDuty%20cycle%20is%2016784%20(50%25%20duty%20cycle).%26nbsp%3B%3C%2FSTRONG%3E%26nbsp%3Bwith%20those%20period%20and%20duty%20cycle%20value%20given%20to%20%3CSTRONG%3Efast%20update%20block%2C%20%3C%2FSTRONG%3Ethe%20%3CSTRONG%3Eoutput%20pulse%20is%20with%20different%20frequency%20and%20different%20duty%20cycle.%3C%2FSTRONG%3E%26nbsp%3B%3C%2FP%3E%3CP%3E2.%20And%20want%20to%20generate%20pwm%20pulse%20for%20frequency%20-%20%3CSTRONG%3E1000%20Hz%20%3C%2FSTRONG%3Efor%20that%20%3CSTRONG%3Eperiod%20value%20is%2029(Core%20clock%20-%20120MHz%2C%20Clock%20divider%20value%20is%20255%20and%20internal%20prescalar%20value%20is%2016)%26nbsp%3B%3C%2FSTRONG%3Eand%20%3CSTRONG%3EDuty%20cycle%20is%2031129(95%25%20duty%20cycle).%26nbsp%3B%3C%2FSTRONG%3E%26nbsp%3Bwith%20those%20period%20and%20duty%20cycle%20value%20given%20to%20%3CSTRONG%3Efast%20update%20block%2C%20%3C%2FSTRONG%3Ethe%20%3CSTRONG%3Eoutput%20pulse%20is%20with%20different%20frequency%20and%20different%20duty%20cycle.%3C%2FSTRONG%3E%26nbsp%3B%3C%2FP%3E%3CP%3EBut%20the%20Pins%20we%20are%20using%20PTA0%20%26amp%3B%20PTC10%2C%20in%20that%20pins%20we%20can%20be%20able%20to%20see%20the%20output%20waveform%20with%20different%20frequency%20%26amp%3B%20different%20duty%20cycle.%26nbsp%3B%3C%2FP%3E%3CP%3Eand%26nbsp%3B%3CSPAN%3Ewe%20need%20to%20configure%20the%20'PTC10'%20pin%20as%20the%20Low%20side%20pin%20with%20lcu%20configuration.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ewe%20have%20attached%20the%20photos%20by%20steps%20of%20which%20we%20configured.%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EStep-1%3A%20Pin%20configuration%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_0-1733286929488.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_0-1733286929488.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313904iC901BE827AFEB967%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_0-1733286929488.png%22%20alt%3D%22Vijay98_0-1733286929488.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EStep-2%3A%20Pin%20config%20in%20port%20driver%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_1-1733286929217.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_1-1733286929217.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313905i811C5E8FF08196AF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_1-1733286929217.png%22%20alt%3D%22Vijay98_1-1733286929217.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EStep-3%3A%20Pwm%20driver%20configuration%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_2-1733286929646.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_2-1733286929646.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313906i66452306BB00772C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_2-1733286929646.png%22%20alt%3D%22Vijay98_2-1733286929646.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_3-1733286929440.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_3-1733286929440.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313907i7676F65D7D678C45%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_3-1733286929440.png%22%20alt%3D%22Vijay98_3-1733286929440.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EStep-4%3A%20Trigmux%20configuration%20for%20Ptc10%20(Lcu1_out11)%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_4-1733286929278.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_4-1733286929278.png%22%20style%3D%22width%3A%20398px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313909i18BF56C64FE47A7B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_4-1733286929278.png%22%20alt%3D%22Vijay98_4-1733286929278.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EStep-5%3A%20Lcu_instance%20configuration%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_5-1733286929538.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_5-1733286929538.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313908i8325AD253A2CFD52%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_5-1733286929538.png%22%20alt%3D%22Vijay98_5-1733286929538.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EStep-6%3A%20Lcu%20logic%20input%20config%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_6-1733286929696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_6-1733286929696.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313910i09A0E56EB6F17D06%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_6-1733286929696.png%22%20alt%3D%22Vijay98_6-1733286929696.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EStep-7%3A%20Lcu%20logic%20output%20configuration%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_7-1733286929685.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_7-1733286929685.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313911iB8F2B2027AF62590%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_7-1733286929685.png%22%20alt%3D%22Vijay98_7-1733286929685.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EKindly%20check%20this%20configuration%2C%20we%20think%20that%20we%20have%20made%20some%20small%20mistake%20in%20this.%3C%2FP%3E%3CP%3EWe%20want%20to%20generate%20High%20side%20pwm%20pulse%20in%20%22PTA0%22%20-%20this%20is%20ok%3C%2FP%3E%3CP%3Eand%20Low%20side%20PWM%20pulse%20in%20%22PTC10%22%20-%20this%20we%20tried%20but%20the%20waveform%20is%20not%20able%20to%20view%20without%20%3CSTRONG%3Efast%20update%20method.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EKindly%20help%20us%20with%20this%20configuration.%3C%2FP%3E%3CP%3EThanks%20%26amp%3B%20regards%2C%3C%2FP%3E%3CP%3EVijay%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2003791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2003791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233667%22%20target%3D%22_blank%22%3E%40MN_TL_24%3C%2FA%3E%26nbsp%3B%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThank%20you%20for%20reading%20the%20post%20on%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FPwm-delay-in-trigger-pulse%2Fm-p%2F1993066%2Fhighlight%2Ftrue%23M9749%22%20target%3D%22_blank%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EThe%20pinout%20configuration%20in%20that%20thread%20is%20for%20enabling%20the%20Logic%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ECell%200%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Ewith%20it's%20corresponding%20pins.%3C%2FP%3E%0A%3CP%3EUnfortunately%2C%20the%20pin%20PTC10%20is%20tied%20to%20another%20Logic%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ECell%201%3C%2FSTRONG%3E%2C%20Output%3CSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E11%3C%2FSTRONG%3E%2C%20namely%3CSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3ELC1_Out11%3C%2FSTRONG%3E%2C%20as%20state%20in%20the%20Pin%20Manager%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1732802557969.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1732802557969.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313143i7BDB6A2EC2B922CA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1732802557969.png%22%20alt%3D%22stefanvlad_0-1732802557969.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EWhat%20output%20pin%20from%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ELCU0%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Edo%20you%20want%20to%20generate%20on%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EPTC10%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Epin%3F%20From%20my%20understanding%20you%20want%20to%20output%20PWM_Modulator%20from%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EPTD2%26nbsp%3B%3C%2FSTRONG%3Eon%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EPTC10%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Epin.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EWe%20can%20check%20what%20options%20we%20have%20for%20that%20PTC10%20in%20Pin%20Manager%2C%20there%20is%20an%20option%20for%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3Eemios_0_ch6%3C%2FSTRONG%3E%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_1-1732802558139.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_1-1732802558139.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313145iB2AEAB1477CE678E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_1-1732802558139.png%22%20alt%3D%22stefanvlad_1-1732802558139.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EWe%20can%20use%20it%20as%20this%20and%20add%20another%20eMIOS%20channel%20in%20PWM%20driver%2C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EEMIOS_0%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eand%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ECH_6%3C%2FSTRONG%3E%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1732802558540.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1732802558540.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313144i78955F9CE7B33889%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1732802558540.png%22%20alt%3D%22stefanvlad_2-1732802558540.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThen%20we%20add%20another%20PWM%20channel%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_3-1732802558189.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1732802558189.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313147iA8AE36FF75CB0A53%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_3-1732802558189.png%22%20alt%3D%22stefanvlad_3-1732802558189.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThen%20we%20need%20to%20enable%20it%20in%20Port%20peripheral%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_4-1732802558073.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1732802558073.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313146i76E884CD4A630CD3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_4-1732802558073.png%22%20alt%3D%22stefanvlad_4-1732802558073.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EAfter%20this%20we%20need%20to%20Update%20Code%20and%20save%20configuration%2C%20and%20modify%20the%20Model%20to%20update%20Duty%2BPeriod%20on%20the%20new%20channel%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_5-1732802558185.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1732802558185.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313148i2E5A5A881A48F1FC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_5-1732802558185.png%22%20alt%3D%22stefanvlad_5-1732802558185.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESave%20the%20model%20and%20Build%20%2C%20and%20program%20the%20board%2C%20we%20get%20the%20new%20eMIOS%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EPWMC_Modulator%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eon%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EPTC10%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Epin%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_6-1732802557917.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1732802557917.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313149iC6CFFD38DFBE5C7E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_6-1732802557917.png%22%20alt%3D%22stefanvlad_6-1732802557917.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHope%20this%20solves%20your%20questions%2C%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2002925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPwm_Icu_pin_config_issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2002925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Nxp%20Team%2C%3C%2FP%3E%3CP%3ECurrently%20we%20are%20working%20in%20Pwm%20pulse%20generation%20using%20Lcu%20%26amp%3B%20Trigmux%20with%20the%20help%20of%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FPwm-delay-in-trigger-pulse%2Fm-p%2F1995720%23M9763%22%20target%3D%22_blank%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%20-%20NXP%20Community%3C%2FA%3E%26nbsp%3Bthis%20post.%3C%2FP%3E%3CP%3EWe%20want%20to%20route%20the%3CSTRONG%3E%20%22PTA3%22%3C%2FSTRONG%3E%20pin%20which%20pwm%20is%20already%20generated%20by%20Lcu%20configuration%20to%20%3CSTRONG%3E%22PTC10%22%26nbsp%3B%3C%2FSTRONG%3Epin%20by%20Lcu%20configuration.%3C%2FP%3E%3CP%3EBut%20we%20are%20trying%20to%20configure%20the%20PTC10%20pin%20(LCU1_out11)%20in%20LCU%20configuration%20and%20trying%20to%20generate%20pwm%20pulse.%20But%20we%20are%20unable%20to%20generate%20pulse%20in%20that%20pin.%20Here%20by%2C%20we%20are%20attached%20the%20file%20and%20steps%20that%20we%20are%20configured.%3C%2FP%3E%3CP%3EStep-1%3A%20Pin%20configuration%20for%20PTC-10%20pin.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_0-1732715275333.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_0-1732715275333.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312874i0B13797775D1AD12%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_0-1732715275333.png%22%20alt%3D%22Vijay98_0-1732715275333.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EStep-2%3A%20Port%20configuration%20for%20Ptc10%20pin.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_1-1732715453267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_1-1732715453267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312875iED5778B0142967FF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_1-1732715453267.png%22%20alt%3D%22Vijay98_1-1732715453267.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EStep-3%3A%20Pwm%20peripheral%20configuration%20for%20PTC-10%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_2-1732715510985.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_2-1732715510985.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312878i1E6C68F652147495%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_2-1732715510985.png%22%20alt%3D%22Vijay98_2-1732715510985.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_3-1732715524321.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_3-1732715524321.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312879i4970309662F1A813%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_3-1732715524321.png%22%20alt%3D%22Vijay98_3-1732715524321.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EStep-4%3A%20Trigmux%20configuration%20for%20Ptc10%20-%20LCU1_out11%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_4-1732715577831.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_4-1732715577831.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312880i12637171241189B6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_4-1732715577831.png%22%20alt%3D%22Vijay98_4-1732715577831.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EStep-5%3A%20Lcu%20configuration-%20lcu%20logic%20instance%20config%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_5-1732715627968.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_5-1732715627968.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312881i20F1BDEC3B2705A9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_5-1732715627968.png%22%20alt%3D%22Vijay98_5-1732715627968.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EStep-6%3A%20Lcu%20configuration%20-%20Lcu%20input%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_6-1732715660529.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_6-1732715660529.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312882iF39FFE6097CEA844%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_6-1732715660529.png%22%20alt%3D%22Vijay98_6-1732715660529.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EStep-7%3A%20Lcu%20configuration%20-%20Lcu%20output%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_7-1732715691206.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_7-1732715691206.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312883iFD7883BD0B8C1878%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_7-1732715691206.png%22%20alt%3D%22Vijay98_7-1732715691206.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EStep-8%3A%20In%20model%20-%26gt%3B%20initialize%20system%20-%26gt%3B%20configured%20Mcl%20output%20state%20-%204%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Vijay98_8-1732715733740.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vijay98_8-1732715733740.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312884i6E2D9439D0377BB7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Vijay98_8-1732715733740.png%22%20alt%3D%22Vijay98_8-1732715733740.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EKindly%20help%20to%20check%20this%20configuration%20for%20routing%20the%20Lcu%20output%20of%20'PTA3'%20pwm%20to%20'PTC10'%20pin%20with%20LCU%20configuration.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EKindly%20help%20us%20to%20resolve%20this%20issue.%3C%2FP%3E%3CP%3EThanks%20%26amp%3B%20regards%2C%3C%2FP%3E%3CP%3EVijay%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F199423%22%20target%3D%22_blank%22%3E%40dragostoma%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F100054%22%20target%3D%22_blank%22%3E%40Irina_Costachescu%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F221383%22%20target%3D%22_blank%22%3E%40Adrian_Gherca%3C%2FA%3E%26nbsp%3B%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229388%22%20target%3D%22_blank%22%3E%40DrKarthi%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226537%22%20target%3D%22_blank%22%3E%40Kavin_raj_mbd%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1998177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1998177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThis%20is%20normal%20%2C%20since%20the%20Logic%20Analyzer%20software%20is%20plotting%20the%20captured%20samples%20in%20a%20increasing%20time%20domain%20on%20the%20X%20axis.%3C%2FP%3E%0A%3CP%3EThe%20effect%20you%20are%20seeing%20in%20the%20video%20%2C%20i%20think%20it%20is%20due%20to%20aliasing%20in%20between%20the%20captured%20PWM%20frequency%2C%20the%20Logic%20software%20rendering%20and%20the%20display%20refresh%20rate.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThe%20only%20issue%20i%20could%20find%20is%20regarding%20the%20PWM%20frequency%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1732126556146.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1732126556146.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311495iE7F3E6218AE01C6B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1732126556146.png%22%20alt%3D%22stefanvlad_0-1732126556146.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBut%20this%20is%20due%20to%20PWM%20generation%20based%20on%20the%20PLL%20jitter%2C%20there%20is%20information%20about%20this%20jitter%20in%20the%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FS32K3xx.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32K3xx%20Data%20Sheet%3C%2FA%3E%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_1-1732126667330.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_1-1732126667330.png%22%20style%3D%22width%3A%20335px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311496i55B7A436CC60A75A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_1-1732126667330.png%22%20alt%3D%22stefanvlad_1-1732126667330.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESince%20the%20PLL%20clock%20is%20generating%20the%20CORE_CLK%20that%20goes%20into%20EMIOS_CLK%20that%20generates%20the%20PWM%20signals%2C%20according%20to%20this%20diagram%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1732126722563.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1732126722563.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311497iAC6A11EC1745BE0D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1732126722563.png%22%20alt%3D%22stefanvlad_2-1732126722563.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EHope%20this%20answered%20your%20questions%2C%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1996919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1996919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Nxp%20team%2C%3C%2FP%3E%3CP%3EWe%20are%20also%20working%20in%20Pwm_trigmux_lcu%20to%20generate%20the%20pwm%20pulse%20in%20Lcu%20pins.%3C%2FP%3E%3CP%3EAnd%20we%20have%20checked%20the%20model%20given%20by%20nxp%20team%20%22%3CSPAN%3Es32k312_pwm_lcu_mod_carrier_s32ct.zip%22%20and%20we%20have%20also%20used%20'PTA0'%20as%20the%20High%20side%20pin%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ebut%20we%20need%20to%20configure%20the%20'PTC10'%20pin%20as%20the%20Low%20side%20pin%2C%20but%20we%20can't%20be%20able%20to%20see%20the%20waveform%20in%20Ptc%2010%20pin.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ewe%20have%20attached%20the%20photos%20by%20steps%20of%20which%20we%20configured.%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EStep-1%3A%20Pin%20configuration%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_0-1731999687067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_0-1731999687067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311170iD072515B8013D201%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_0-1731999687067.png%22%20alt%3D%22MN_TL_24_0-1731999687067.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EStep-2%3A%20Pin%20config%20in%20port%20driver%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_1-1731999717746.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_1-1731999717746.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311171i0EFF1CE76A120130%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_1-1731999717746.png%22%20alt%3D%22MN_TL_24_1-1731999717746.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EStep-3%3A%20Pwm%20driver%20configuration%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_2-1731999753141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_2-1731999753141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311172i78E426A51630E139%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_2-1731999753141.png%22%20alt%3D%22MN_TL_24_2-1731999753141.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_3-1731999761421.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_3-1731999761421.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311173iD575780E1D5B1741%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_3-1731999761421.png%22%20alt%3D%22MN_TL_24_3-1731999761421.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EStep-4%3A%20Trigmux%20configuration%20for%20Ptc10%20(Lcu1_out11)%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_4-1731999794773.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_4-1731999794773.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311174i7D2A743CD776D6FE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_4-1731999794773.png%22%20alt%3D%22MN_TL_24_4-1731999794773.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EStep-5%3A%20Lcu_instance%20configuration%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_5-1731999870145.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_5-1731999870145.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311175i8C14D0B95D853F62%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_5-1731999870145.png%22%20alt%3D%22MN_TL_24_5-1731999870145.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EStep-6%3A%20Lcu%20logic%20input%20config%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_6-1731999904508.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_6-1731999904508.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311176iB45C2DF9198BD307%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_6-1731999904508.png%22%20alt%3D%22MN_TL_24_6-1731999904508.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EStep-7%3A%20Lcu%20logic%20output%20configuration%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MN_TL_24_7-1731999930115.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MN_TL_24_7-1731999930115.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311178i93DC7EABDE236D41%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MN_TL_24_7-1731999930115.png%22%20alt%3D%22MN_TL_24_7-1731999930115.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EKindly%20check%20this%20configuration%2C%20we%20think%20that%20we%20have%20made%20some%20small%20mistake%20in%20this.%3C%2FP%3E%3CP%3EWe%20want%20to%20generate%20High%20side%20pwm%20pulse%20in%20%22PTA0%22%20-%20this%20is%20ok%3C%2FP%3E%3CP%3Eand%20Low%20side%20PWM%20pulse%20in%20%22PTC10%22%20-%20this%20we%20tried%20but%20the%20waveform%20is%20not%20able%20to%20view.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EKindly%20help%20us%20to%20resolve%20this%20issue.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%20%26amp%3B%20regards%2C%3C%2FP%3E%3CP%3EMN_TL%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1995720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1995720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThanks%20for%20the%20update.%3C%2FP%3E%3CP%3Ewe%20have%20checked%20the%20model%20and%20its%20output%20pwm%20pulse%20in%26nbsp%3B%3CSPAN%3ESaleae%20Logic%208%26nbsp%3B(logic%20analyzer)%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ewe%20can%20be%20able%20to%20see%20the%20pulses%20and%20checked%20that%20the%26nbsp%3Bdelay%20is%20reduced%20but%20we%20have%20an%20issue%20is%20that%20the%20pulse%20inside%20the%20Carrier%20(i.e.%2C%20the%20modulator%20pulse%20in%20PTD2%20%26amp%3B%20PTA0)%20is%20changing%20like%20keep%20on%20running.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20have%20attached%20the%20video%20of%20the%20pulses%20that%20we%20captured%20using%20logic%20analyzer%20and%20its%20logic%20analyzer%20file%20with%20this%20post.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ewe%20have%20tried%20giving%20different%20duty%20cycle%20and%20period%20for%20both%20the%20pulses%2C%20but%20we%20are%20facing%20that%20issue%20(modulator%20pulse%20is%20running).%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EKindly%20help%20us%20to%20resolve%20this%20issue%20%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EThanks%20%26amp%3B%20regards%2C%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EVijay%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1993066%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1993066%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ETo%20change%20the%20LCU%20output%20pins%20it%20is%20not%20easy(feasible)%2C%20since%20all%20the%20Inputs%2FOutputs%20are%20tightly%20related%20to%20the%20existing%20LCU0%20pins%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1731437169645.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1731437169645.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310089i20E9151A7DC2FFEB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1731437169645.png%22%20alt%3D%22stefanvlad_2-1731437169645.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EInstead%2C%20we%20can%20use%20TrgMux%20to%20re-route%20the%20%3CSTRONG%3EPTA3%3C%2FSTRONG%3E%20output%20to%26nbsp%3B%3CSTRONG%3EPTA0%2C%3C%2FSTRONG%3E%20there%20are%20multiple%20steps%20required%3A%3C%2FP%3E%0A%3CP%3E1.%20in%20the%20MCL%20Configuration%20%2C%20Trgmux%20Logic%20Instance%2C%20add%20input%20LCU0_LC0_OUT_I2%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1731436994058.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1731436994058.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310086i743705CD02B110D1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1731436994058.png%22%20alt%3D%22stefanvlad_0-1731436994058.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2.%20LCU%20Configuration%2C%20add%20an%20Lcu%20Logic%20Input%2C%20set%20to%20%3CSTRONG%3ELCU_IP_MUX_SEL_LU_IN_2%3C%2FSTRONG%3E%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_3-1731437340855.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1731437340855.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310091i34E91FC8DFBB4BE3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_3-1731437340855.png%22%20alt%3D%22stefanvlad_3-1731437340855.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E3.%20LCU%20Logic%20Output%2C%20add%20another%20ouput%20to%20LC_1%2C%20set%20to%26nbsp%3B%3CSTRONG%3ELCU_IP_HW_OUTPUT_0%3C%2FSTRONG%3E%20%3A%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_4-1731437436087.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1731437436087.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310094i15604CC0391A4027%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_4-1731437436087.png%22%20alt%3D%22stefanvlad_4-1731437436087.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E4.%20In%20the%20Simulink%20model%2C%20Initialize%20Function%20we%20need%20to%20add%20another%20%3CSTRONG%3EMCL_LCU%20Output%3C%2FSTRONG%3E%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_5-1731437557652.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_5-1731437557652.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310095iD5FF712C26317984%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_5-1731437557652.png%22%20alt%3D%22stefanvlad_5-1731437557652.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EI%20have%20updated%20the%20model%20with%20%3CSTRONG%3EPWM_FastUpdate%3C%2FSTRONG%3E%20functions%2C%20that%20can%20be%20used(applied)%20also%20in%20your%20original%20model%20that%20used%20%3CSTRONG%3ESoftware%20Trigger%3C%2FSTRONG%3E%2C%20to%20improve%20the%20update%20time%2C%20in%20my%20model%20this%20takes%20around%20%3CSTRONG%3E7us%3C%2FSTRONG%3E%20to%20update%20%3CSTRONG%3E2%20PWM%3C%2FSTRONG%3E%20channels%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_8-1731438119981.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_8-1731438119981.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310102i94BF74EF435147C0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_8-1731438119981.png%22%20alt%3D%22stefanvlad_8-1731438119981.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EVisualize%20the%20results%20with%20the%20logic%20analyzer(Saleae%20Logic%208%20or%20others%20from%20ebay%2FAliexp)%20using%20the%20Logic2%20software%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_6-1731437774328.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_6-1731437774328.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310100iE0EB1499354F2CDE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_6-1731437774328.png%22%20alt%3D%22stefanvlad_6-1731437774328.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EAlso%20i%20have%20update%20the%20FreeMASTER%20model%2C%20so%20now%20it%20can%20change%20both%20Duty%20cycles%20and%20same%20Period%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_7-1731437885339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_7-1731437885339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310101iAD335AD20160D0F7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_7-1731437885339.png%22%20alt%3D%22stefanvlad_7-1731437885339.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThis%20is%20all%20from%20my%20side%2C%20you%20can%20find%20the%20updated%20model%20in%20the%20archive%3A%20%3CSTRONG%3Es32k312_pwm_lcu_mod_carrier_s32ct%3C%2FSTRONG%3E.zip%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_9-1731438229164.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_9-1731438229164.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F310103i47A0D30234C7D34E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_9-1731438229164.png%22%20alt%3D%22stefanvlad_9-1731438229164.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20response%3C%2FP%3E%3CP%3EWe%20have%20checked%20the%20waveform%2C%26nbsp%3B%3C%2FP%3E%3CP%3Eand%20right%20now%20we%20need%20to%20change%20only%20the%20LCU%20pins%20for%20our%20hardware%20for%20that%2C%3C%2FP%3E%3CP%3E1.%20In%20MCL%20component%20-%26gt%3B%20LCU%20configuration%20what%20are%20the%20configuration%20need%20to%20be%20changed%3F%26nbsp%3B%20(for%20pin%20change)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EFor%20ex%3A%20I%20need%20to%20change%20the%20pin%20from%20%3CSTRONG%3EPTA3%20to%20PTA0%3C%2FSTRONG%3E%20and%20i%20configured%20pins%20in%20pin%20configuration%20%26amp%3B%20in%20peripherals%20port%20has%20been%20configured%20and%20then%20in%20%3CSTRONG%3ELcu%20how%20to%20configure%20that%20pin%3C%2FSTRONG%3E%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%20which%20logic%20analyzer%20is%20used%20to%20measure%20the%20pwm%20signal%20from%20your%20side%3F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EThanks%20%26amp%3B%20regards%2C%3C%2FP%3E%3CP%3EEsakki.P%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1988147%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1988147%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EGlad%20to%20hear%20that%20this%20works%20better%2C%3C%2FP%3E%0A%3CP%3EI%20saw%20the%20issue%20presented%20in%20the%20Video%2C%20maybe%20there%20is%20a%20problem%20with%20the%20Oscilloscope%20trigger%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EIn%20my%20case%20the%20duty%20cycle%20is%20changed%20only%20when%20i%20change%20it%20in%20FreeMASTER%2C%20otherwise%20it%20is%20kept%20constant%2C%20as%20in%20the%20picture%20below%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_1-1730827343375.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_1-1730827343375.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F308743iAB46DC7B22F59043%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stefanvlad_1-1730827343375.png%22%20alt%3D%22stefanvlad_1-1730827343375.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ECan%20you%20check%20the%20same%20pins%20with%20a%20logic%20analyzer%3F%26nbsp%3B%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1987745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1987745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EWe%20tried%20the%20model%20attached%20with%20this%20post%20and%20we%20can%20be%20able%20to%20Change%20the%20period%20and%20duty%20cycle%20with%20this%20model%20and%20able%20to%20see%20the%20waveform.%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20support%20for%20this%20method.%3C%2FP%3E%3CP%3EBut%20we%20have%20a%20doubt%20that%20the%20modulator%20wave%20inside%20the%20carrier%20wave%20gets%20keep%20on%20updating%20(running)%20-%26gt%3B%20kindly%20see%20the%20video%20attached%20with%20this%20post.%3C%2FP%3E%3CP%3EIt%20is%20ok%20for%20the%20modulator%20wave%20is%20running%20like%20that%20or%20can%20we%20stop%20that%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%20%26amp%3B%20regards%3C%2FP%3E%3CP%3EVijay%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1984080%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1984080%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%26nbsp%3B%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229388%22%20target%3D%22_blank%22%3E%40DrKarthi%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E1.%20For%20the%20first%20%3CSTRONG%3ESoftware%20enable%2Fdisable%20%3C%2FSTRONG%3EI%20have%20looked%20in%20your%20attached%20model%20and%20saw%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_4-1730226807702.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_4-1730226807702.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F307521iE1A4DBC64A8C3583%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_4-1730226807702.png%22%20alt%3D%22stefanvlad_4-1730226807702.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EIn%20the%20model%20above%2C%20i%20could%20not%20find%20the%20missing%20%3CSTRONG%3EPWM_FastUpdate%3C%2FSTRONG%3E%20%3CSTRONG%3Eblocks%3C%2FSTRONG%3E%2C%20as%26nbsp%3B%3CSPAN%3Ein%20the%20model%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3Es32k344_mc_bldc_s32ct%2C%26nbsp%3B%3C%2FSTRONG%3Etake%20a%20closer%20look%20at%20the%20picture%20below%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1730225879850.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1730225879850.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F307517i3F589127E284E689%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1730225879850.png%22%20alt%3D%22stefanvlad_0-1730225879850.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThere%20are%20%3CSTRONG%3E4%20blocks%3C%2FSTRONG%3E%20needed%20for%20%3CSTRONG%3Eone%20PWM%20channel%3C%2FSTRONG%3E%2C%20and%20to%20be%20run%20in%20that%20%3CSTRONG%3Especific%20order%3C%2FSTRONG%3E%3A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3EPwm_FastUpdateDisableOU%3C%2FLI%3E%0A%3CLI%3EPwm_FastUpdateSetUCRegA%3C%2FLI%3E%0A%3CLI%3EPwm_FastUpdateSetUCRegB%3C%2FLI%3E%0A%3CLI%3EPwm_FastUpdateEnableOU%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3EAlso%20the%20Channel%20Mask%20value%20is%20not%20%220%22%20in%20the%26nbsp%3B%3CSTRONG%3Es32k344_mc_bldc_s32ct%20%3C%2FSTRONG%3Emodel%2C%20it%20is%20defined%20as%26nbsp%3B%3CSPAN%3EMBD_APP_PWM_MASK%20%3D%20uint32(0xE00)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThis%20steps%20are%20a%20proper%20implementation%20that%20can%20help%20you%20achieve%20better%20results.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E2.%20For%20the%20%3CSTRONG%3EHardware%20generation%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3Bof%20the%20PWM_Carrier%2C%20to%20be%20generated%20using%20the%20eMIOS%20with%20TRGMUX%20and%20LCU%2C%20i%20have%20updated%20the%20model%20and%20configuration%20to%20use%26nbsp%3BOPWFMB%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_1-1730226281277.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_1-1730226281277.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F307518i1EAAD753EB7261C3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_1-1730226281277.png%22%20alt%3D%22stefanvlad_1-1730226281277.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThe%20PWM_Mod%2B%20PWM_Carrier%20Period%20and%20Duty%20cycle%20values%20can%20be%20modified%20from%20FreeMASTER%20while%20the%20code%20is%20running%20on%20the%20board%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1730226406368.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1730226406368.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F307519i6EF0F8CAEEB45302%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1730226406368.png%22%20alt%3D%22stefanvlad_2-1730226406368.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ENow%20the%20variable%20frequency%20and%20duty%20cycle%20can%20be%20changed%20for%20both%20channels%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_3-1730226465678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1730226465678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F307520iF1BE059E82CE8DAC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_3-1730226465678.png%22%20alt%3D%22stefanvlad_3-1730226465678.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EPlease%20find%20the%20attached%20model%20in%20%3CSTRONG%3Es32k312_pwm_lcu_mod_carrier_s32ct%3C%2FSTRONG%3E.zip%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1983521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1983521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3Ekindly%20update%20the%20solution%20for%20above%20issue.%3C%2FP%3E%3CP%3Eor%20it%20will%20be%20helpful%20if%20we%20discuss%20in%20a%20teams%20call.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1973315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1973315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203341%22%20target%3D%22_blank%22%3E%40stefanvlad%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E1.%20For%20the%20first%20approach%2C%20%3CSTRONG%3EFast%20update%20function%26nbsp%3B%3C%2FSTRONG%3Ewe%20tried%20with%20fast%20update%20function%20in%20our%20model%20and%20checked%20but%20there%20is%20a%20variable%20delay%20in%20pwm%202%20pulse.%26nbsp%3Bis%20there%20any%20example%20model%20available%20for%20the%20previous%20mentioned%20requirement.%3C%2FP%3E%3CP%3Eand%20i%20have%20attached%20the%20file%20%22Test_in_new%22.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_0-1728903881304.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_0-1728903881304.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F304536i411B8B19125FA065%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_0-1728903881304.png%22%20alt%3D%22Esakki_0-1728903881304.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%20And%20for%20the%20second%20approach%2C%26nbsp%3B%3C%2FP%3E%3CP%3EThe%20program%20which%20shared%20was%20running%20in%20opwmb%20and%20has%20counter%20bus%20of%20bcde.%20And%20we%20seen%20change%20in%20periods%20not%20happening%2C%20its%20in%20fixed%20frequency%20with%20variable%20dutycycle.%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CU%3EObservation%20with%20your%20shared%20model(S32k312_pwm_icu_S32ct)%3A%3C%2FU%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E1.%20High%20side%20frequency%20always%20at%20259.63HZ%2C%20refer%20image.%3C%2FP%3E%3CP%3E%3CU%3E(our%20requirement%3A%20it%20need%20to%20change%20from%200.1HZ%20to%20150HZ)%3C%2FU%3E%3C%2FP%3E%3CP%3E2.%20Low%20side%20Frequency%20always%20at%202.8Khz%20refer%20image%3C%2FP%3E%3CP%3E%3CU%3E(Our%20requirement%3A%20its%20need%20to%20change%20from%200.1Hz%20to%2012Khz%20based%20on%20ON%20time%20of%20High%20side%20frequency)%3C%2FU%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_1-1728906825360.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_1-1728906825360.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F304542i8FD100362F0DC56A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_1-1728906825360.jpeg%22%20alt%3D%22Esakki_1-1728906825360.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ewe%20tried%20changing%20the%20mode%20and%20counter%20bus%20to%20'OPWFMB'%20%26amp%3B%20'internal%20bus'%20but%20the%20PWM-2%20pulse%20is%20not%20getting%20synchronized%20with%20PWM1%20pulse.%3C%2FP%3E%3CP%3Ewe%20want%20to%20change%20one%20pwm%20(PWM-1)%20both%20period%20and%20duty%20cycle%20for%20different%20frequency%20(OPWFMB)%20from%20Application%20and%20PWM-2%20has%20to%20turned%20on%20and%20off%20based%20on%20PWM-1%20ON%20time.%3C%2FP%3E%3CP%3EAnd%20i%20have%20attached%20the%20file%20below%20as%20%22Nxp_pwm%22%3C%2FP%3E%3CP%3EKindly%20help%20us%20to%20resolve%20this%20issue%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%20%26amp%3B%20regards%2C%3C%2FP%3E%3CP%3EEsakki.P%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229388%22%20target%3D%22_blank%22%3E%40DrKarthi%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226537%22%20target%3D%22_blank%22%3E%40Kavin_raj_mbd%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1966480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1966480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20have%20opened%20the%20archived%20model%3A%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1727971560612.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1727971560612.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F302616iE8CA6CC7F6BEF6D3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1727971560612.png%22%20alt%3D%22stefanvlad_0-1727971560612.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EAnd%20flashed%20it%20on%20the%20S32K312EVB-Q172%20board%2C%20then%20connected%20Logic%20analyzer%20probes%20and%20got%20this%20signals%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_1-1727971604512.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_1-1727971604512.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F302617i569DC3408491E1AF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_1-1727971604512.png%22%20alt%3D%22stefanvlad_1-1727971604512.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EUnfortunately%20the%20PTC10%20signal%20seems%20to%20be%20reversed%20from%20your%20%22Photo%20-%202%3A%20no%20delay%20for%20pwm%202.%22%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1727971655097.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1727971655097.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F302618i8DA76FBD9319E560%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1727971655097.png%22%20alt%3D%22stefanvlad_2-1727971655097.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBut%20nevertheless%20i%20understood%20want%20you%20want%20to%20achieve%2C%20an%20PWM%20signal%20with%20lower%20Frequency%20%2C%20usually%20called%20a%20PWM_Modulator%20and%20a%20signal%20with%20a%20higher%20(11x)%20frequency%2C%20called%20a%20PWM_Carrier.%3C%2FP%3E%0A%3CP%3Ethere%20are%20two%20approaches%20to%20do%20this%3A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CSTRONG%3ESoftware%20enable%2Fdisable%3C%2FSTRONG%3E%20of%20PWM_Carrier%20on%20the%20triggered%20PWM_Modulator%20interrupt%2C%20this%20is%20the%20implementation%20that%20you%20have%20tried.%20The%20disadvantage%20is%20the%20delay%20is%20not%20constant%20as%20you%20saw%2C%20one%20way%20to%20correct%20this%20is%20to%20check%20the%20peripheral%20priorities%20in%20the%20Interrupt%20Controller%2C%20another%20way%20is%20to%20implement%20the%20FastUpdate%20function%20for%20PWM%2C%20we%20have%20an%20example%20in%20the%20model%26nbsp%3B%3CSTRONG%3Es32k344_mc_bldc_s32ct%3C%2FSTRONG%3E%3A%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_3-1727972253418.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_3-1727972253418.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F302620iE50FE8C92F1E184D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_3-1727972253418.png%22%20alt%3D%22stefanvlad_3-1727972253418.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%3CSTRONG%3EHardware%20generation%3C%2FSTRONG%3E%20of%20the%20PWM_Carrier%2C%20to%20be%20generated%20using%20the%20eMIOS%20with%20TRGMUX%20and%20LCU%3A%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1728053964163.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1728053964163.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F302735i186728247778382E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1728053964163.png%22%20alt%3D%22stefanvlad_0-1728053964163.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3EWith%20this%20configuration%20i%20was%20able%20to%20generate%20the%20proper%20PWM%20signals%3A%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_2-1728054330569.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_2-1728054330569.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F302737i69DD0AB018E8FBD4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_2-1728054330569.png%22%20alt%3D%22stefanvlad_2-1728054330569.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%0A%3CP%3EThis%20approach%20is%20a%20bit%20more%20complex%2C%20but%20it%20will%20ensure%20the%20delay%20is%20minimum%20and%20controllable.%3C%2FP%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CBR%20%2F%3E%0A%3CP%3EPlease%20try%20the%20FastUpdatePWM%20implementation%20in%20your%20model%2C%20or%20you%20can%20test%20the%20attached%20model%20in%26nbsp%3B%3CSTRONG%3Es32k312_pwm_lcu_s32ct.zip%3A%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22stefanvlad_0-1728055832787.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stefanvlad_0-1728055832787.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F302738i3BB3C97D80177C57%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22stefanvlad_0-1728055832787.png%22%20alt%3D%22stefanvlad_0-1728055832787.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ELet%20me%20know%20if%20this%20helps%20you%20and%20have%20a%20great%20weekend%2C%3C%2FP%3E%0A%3CP%3EStefan%20V.%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1958323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1958323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Dragos%2C%3C%2FP%3E%3CP%3EMy%20first%20point%20is%20that%26nbsp%3B%3C%2FP%3E%3CP%3EYes%2C%20we%20are%20generating%20the%20%3CSTRONG%3Epwm%20signal%3C%2FSTRONG%3E%20using%20the%20%3CSTRONG%3Einternal%20counter%3C%2FSTRONG%3E%20for%20%3CSTRONG%3Eemios1_ch0%3C%2FSTRONG%3E%20and%20%3CSTRONG%3Eemios0_ch0%26nbsp%3B%3C%2FSTRONG%3Ein%20%3CSTRONG%3EOPWFMB%3C%2FSTRONG%3E%20mode.%20And%20in%20%3CSTRONG%3Emcl%3C%2FSTRONG%3E%20configuration%20we%20mentioned%20only%20%3CSTRONG%3Eclock%20divider%20value.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EAnd%20yes%2C%20we%20are%20configuring%20the%20same%20configuration%20for%20pwm%20in%20this%20post%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FReg-Raising-edge-and-Falling-edge-detection-issue-S32k344%2Fm-p%2F1949425%2Fhighlight%2Ftrue%23M9454%22%20target%3D%22_blank%22%3ERe%3A%20Reg%3A%20Raising%20edge%20and%20Falling%20edge%20detection%20issue_S32k344%20-%20NXP%20Community.%3C%2FA%3E%3C%2FP%3E%3CP%3EWe%20can%20be%20able%20to%20check%20the%20pwm%20edge%20triggering%20and%20able%20to%20generate%20pwm2%20pulse%20within%20the%20pwm1%20pulse%20on%20time.%3C%2FP%3E%3CP%3EBut%20currently%20we%20are%20facing%20an%20issue%20of%20Certain%20delay%20in%20pwm2%2C%20and%20that%20delay%20is%20not%20constant%20for%20pwm2%20pulse.%26nbsp%3B%3C%2FP%3E%3CP%3EPhoto%20-%201%3A%20820uS%20delay%20for%20pwm%202.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_0-1726804764065.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_0-1726804764065.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F300226i21D570FBFC7BC415%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_0-1726804764065.png%22%20alt%3D%22Esakki_0-1726804764065.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPhoto%20-%202%3A%20no%20delay%20for%20pwm%202.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_1-1726804764536.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_1-1726804764536.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F300228i995AA772836D2AA6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_1-1726804764536.png%22%20alt%3D%22Esakki_1-1726804764536.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPhoto%20-%203%3A%20520uS%20delay%20for%20pwm%202.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Esakki_2-1726804764103.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Esakki_2-1726804764103.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F300227i0F64F164A6E6EF10%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Esakki_2-1726804764103.png%22%20alt%3D%22Esakki_2-1726804764103.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWe%20don't%20know%20how%20to%20reduce%20this%20delay%20or%20make%20it%20as%20a%20constant%20delay.%3C%2FP%3E%3CP%3EKindly%20help%20us%20resolve%20this%20issue.%3C%2FP%3E%3CP%3EI%20have%20attached%20the%20model%20and%20configuration%20with%20this%20post.%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EThanks%20%26amp%3B%20regards%2C%3C%2FP%3E%3CP%3EEsakki.P%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1957783%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Pwm_delay_in_trigger_pulse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1957783%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232522%22%20target%3D%22_blank%22%3E%40Vijay98%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EFirst%20of%20all%2C%20for%20the%20results%20obtained%20and%20the%20displayed%20delay%2C%20were%20the%20recommendations%20from%20this%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FReg-Raising-edge-and-Falling-edge-detection-issue-S32k344%2Fm-p%2F1943519%2Fhighlight%2Ftrue%23M9416%22%20target%3D%22_blank%22%3E%3CSTRONG%3Epost%3C%2FSTRONG%3E%20%3C%2FA%3Ealso%20taken%20into%20account%2C%26nbsp%3Bnamely%20those%20related%20to%20the%20level%20of%20optimization%3F%3C%2FP%3E%0A%3CP%3ESecondly%2C%20I%20would%20like%20to%20mention%20the%20fact%20that%20I%20noticed%20in%20the%20provided%20screenshots%20the%20configuration%20of%20a%20master%20bus%20in%20the%20MCL%20component%2C%20for%20the%20eMIOS%201%20instance.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22dragostoma_0-1726755404693.png%22%20style%3D%22width%3A%20697px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dragostoma_0-1726755404693.png%22%20style%3D%22width%3A%20697px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F300056i911F443E37A717DA%2Fimage-dimensions%2F697x512%3Fv%3Dv2%22%20width%3D%22697%22%20height%3D%22512%22%20role%3D%22button%22%20title%3D%22dragostoma_0-1726755404693.png%22%20alt%3D%22dragostoma_0-1726755404693.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EOn%20the%20other%20hand%2C%20in%20the%20configuration%20of%20the%20PWM%20channel%20I%20notice%20that%20in%20the%20same%20eMIOS%201%20instance%20it%20is%20set%20to%20use%20a%20internal%20counter%2C%20that%20is%2C%20the%20reference%20to%20the%20previously%20mentioned%20master%20bus%20is%20not%20taken%20into%20account%2C%20but%20the%20calculation%20is%20based%20on%20an%20internal%20counter.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22dragostoma_1-1726755451081.png%22%20style%3D%22width%3A%20715px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dragostoma_1-1726755451081.png%22%20style%3D%22width%3A%20715px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F300057i9FD61F8FB539FDFE%2Fimage-dimensions%2F715x592%3Fv%3Dv2%22%20width%3D%22715%22%20height%3D%22592%22%20role%3D%22button%22%20title%3D%22dragostoma_1-1726755451081.png%22%20alt%3D%22dragostoma_1-1726755451081.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EIs%20this%20how%20the%20application%20was%20designed%3F%20Because%20the%20results%20of%20the%20calculations%20are%20totally%20different%20regarding%20the%20counter%20used%2C%20if%20it%20is%20internal%20or%20external.%26nbsp%3BIn%20the%20case%20of%20an%20external%20master%20bus%2C%20when%20calculating%20the%20frequency%20and%20period%20of%20a%20PWM%20signal%2C%20the%20period%20of%20the%20master%20bus%2C%20the%20clock%20divider%20and%20respectively%20the%20master%20bus%20prescalers%20are%20also%20included.%20Conversely%2C%20these%20things%20do%20not%20apply%20to%20the%20use%20of%20an%20internal%20counter.%3C%2FP%3E%0A%3CP%3EThe%20last%20question%20would%20be%20if%20this%20model%20uses%20the%20same%20configuration%20as%20in%20the%20other%20similar%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FReg-Raising-edge-and-Falling-edge-detection-issue-S32k344%2Fm-p%2F1949425%2Fhighlight%2Ftrue%23M9454%22%20target%3D%22_blank%22%3E%3CSTRONG%3Ethread%3C%2FSTRONG%3E%3C%2FA%3E%2C%20because%20in%20order%20to%20fully%20understand%20the%20behavior%20and%20configuration%20of%20the%20application%2C%20it%20can't%20help%20to%20share%20the%20configuration%20project%2C%20along%20with%20the%20model.%3C%2FP%3E%0A%3CP%3ELet%20us%20know%20about%20your%20progress.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EDragos%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
