Problem with discrete integration block with NXP application
krishnareddy
In the above picture, try to work on coulomb+voltage based soc estimation on NXP platform, when i try to feed the initial voltage from voltage based SOC at external input of discrete time integrator, & and build code to NXP platform if i try to read SOC value ( final output ), its not working at all, the external feed is not taking at all.
where on the other side , if we observe the below picture, it is working properly on Arduino platform.
Screenshot 2023-10-16 142901.pngScreenshot 2023-10-16 142901.pngLet us know if any setting need to be done.
Thank you
Krishna
