NXP MBDT code import
1,540件の閲覧回数
saurabhkulkarni123
Hello NXP
We are trying to import nxp mbdt generated code in to S32 IDE for ARM, through ProjectInfo.XML file but whenever we import the code, build option get disabled from the menu and we are not able to build it.
Please give us a reply, Its urgent basis
1,526件の閲覧回数
Irina_Costachescu
Hi @saurabhkulkarni123 ,
Perhaps the solution from this post could be of help in your use case as well. (https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/How-to-export-S32K144-MBDT-Generated-Co...)
Could you please check if the Model-Based Design Toolbox is installed in a path that contains spaces? In this case, please consider following the steps mentioned in the post attached for re-installing the toolbox in a path which does not contain spaces.
Hope this helps,
Irina
