Hi @FW_racer
All NXP`s Model-Based Design Toolbox products were designed to work with specific hardware parts to support also a custom hardware design. So in the case of IMXRT1xxx family, we support different hardware parts(see Release Notes document) so the customers are able to came with their custom boards and hardware designs.
The examples were made to work with the EVKs, indeed, for the purpose of simple demonstration on how to use the toolbox.
For your case, the NXPs Model-Based Design Toolbox for IMXRT1xxx series supports the following hardware parts for the RT1062 MCU:
- MIMXRT1062CVJ5A
- MIMXRT1062CVL5A
- MIMXRT1062DVJ6A
- MIMXRT1062DVL6A
So, if you have a custom board, using one of the MCU supported packages , the toolbox should work with no major modifications. The only thing that you have to modify is the the configuration MEX file that attaches to your model. This file contains all clocks, pins and peripherals configuration.
Hope this helps!
Stefan.
