MBDT toolbox for generating and flashing an example code to S32K12 using J-link.
2,770件の閲覧回数
jyoti_c
Am trying to build and flash the example provided by MBDT for NXP toolbox on to S32K312 board using Jlink.
Am providing path to Jlink executables as below in the image.
But once I try to build and deploy the example on to the board, the Execution is getting stuck at
this line(from log),
C:\Users\sel.mechanical.lab1\AppData\Roaming\MathWorks\MATLAB Add-Ons\Toolboxes\NXP_MBDToolbox_S32K3\S32K3_Examples\pwm\s32k312_pwm_lcu_mod_carrier_s32ct\s32k312_pwm_lcu_mod_carrier_s32ct_ert_rtw>if "~""" == "" ("C:\NXP\S32DS.3.5\Drivers\Segger\JLinkGDBServerCL.exe" -if SWD -speed auto -commanderscript "C:\Users\sel.mechanical.lab1\AppData\Roaming\MathWorks\MATLAB Add-Ons\Toolboxes\NXP_MBDToolbox_S32K3\S32K3_Examples\pwm\s32k312_pwm_lcu_mod_carrier_s32ct\script.jlink" -device S32K312 1>"C:\Users\sel.mechanical.lab1\AppData\Roaming\MathWorks\MATLAB Add-Ons\Toolboxes\NXP_MBDToolbox_S32K3\S32K3_Examples\pwm\s32k312_pwm_lcu_mod_carrier_s32ct\program_board.log" ) else ("C:\NXP\S32DS.3.5\Drivers\Segger\JLinkGDBServerCL.exe" -if SWD -speed auto -jlinkscriptfile "" -commanderscript "C:\Users\sel.mechanical.lab1\AppData\Roaming\MathWorks\MATLAB Add-Ons\Toolboxes\NXP_MBDToolbox_S32K3\S32K3_Examples\pwm\s32k312_pwm_lcu_mod_carrier_s32ct\script.jlink" -device S32K312 1>"C:\Users\sel.mechanical.lab1\AppData\Roaming\MathWorks\MATLAB Add-Ons\Toolboxes\NXP_MBDToolbox_S32K3\S32K3_Examples\pwm\s32k312_pwm_lcu_mod_carrier_s32ct\program_board.log" )
seems like it is waiting for connection continuously.
However, It works when I directly flash (i.e., from S32 Design Studio 3.5)
can you please help me to know what am missing and help to fix this issue.
 MBDT S32K312EVB-Q172   #JLINK
タグ(1)
2,755件の閲覧回数
dragostoma
Hi, @jyoti_c
Thank you for your interest into Model-Based Design Toolbox for S32K3.
Based on the screenshot you provided, the J-Link location appears to be incorrectly configured. This is the primary cause of the error you are encountering.
To successfully deploy using the J-Link interface, the correct JLink.exe location must be specified.
For additional guidance, please refer to the following article, which demonstrates the deployment process using a J-Link device: Interacting with Digital Inputs/Outputs on MR-CANHUBK344
Dragos
4 返答(返信)
2,756件の閲覧回数
dragostoma
Hi, @jyoti_c
Dragos
2,704件の閲覧回数
jyoti_c
Hey @dragostoma ,
Thank you for your support.
I am trying to run freeMaster but getting few errors.
S32K312 board is connect to PC via segger J-link.
Initially when I open **.pmpx file with freeMaster and click on GO, I got this error (image Error_FM.jpj)
I tried to configure few things on the tool but still did not succeed to.( image freeMAster_snip.jpj) with baudrate 11520.
can you please provide me any detailed reference for freeMaster tool configuration using Segger-Jlink.
Also, can you please provide me some detailed reference examples which use potentiometer and ADC ports?
FREEMASTER MBDT #S32k312
Thank you
Jyoti C
2,687件の閲覧回数
dragostoma
Hi, @jyoti_c,
To ensure the J-Link interface is configured correctly in FreeMASTER, please refer to the following documentation:
1. Click on Tools -> Connection Wizard
2. Click Next
3. Select Connect through a debugger probe or on-board debugger interface
4. Select J-Link or J-Trace interface from Segger Microcontroller (Also supports RTT)
5. Select Direct access to target microcontroller memory
6. Click on Read more link in order to access the guide on how to set up the connection using J-Link
7. Press Plug-in Configuration in order to apply the instructions from the above guide
8. Once the configuration is completed and the connection test passes successfully, you can establish a connection to the target board via J-Link.
For detailed examples showcasing the potentiometers and ADC ports, you can refer to the following model examples from adc folder:
  • s32k3xx_adc_ctu_ebt
  • s32k3xx_adc_single_read_s32ct
  • s32k3xx_adc_stream_read_ebt
Dragos
2,670件の閲覧回数
jyoti_c
Hi @dragostoma ,
I tried with the above steps, but I still face with following issue :
1. After making all the configuration , when I click on GO, I get a pop up saying device name is "Unspecified". (image On_Go.jpj )
2. After that , I get an option to select the target. And I select my board i.e. S32K312. (image SelTarget.jpj ) 
3. After that the TestConnection runs proper and I get the connected pop up (image FM_Config.jpg ) 
4. But , once the connection is done, the varible value is getting stuck at whereever it was running. (like if red LED was blinking, it stops at RED. ) ( image StoppingAtLastValue.jpj)
can you help me to know whats the mistake ?
Also, I see my configuration is asking for Jlink Script path, but I dont see it in the configuration GUI thats mentioned in Readmore doc. (image JlinkScriptPath.jpj) 
%3CLINGO-SUB%20id%3D%22lingo-sub-2316817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EJ-link%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81S32K12%20%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%20MBDT%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2316817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%20Jlink%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81MBDT%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%20NXP%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E7%94%A8%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81S32K312%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%81Jlink%20%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%B8%E3%81%AE%E3%83%91%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jyoti_c_0-1770715820371.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jyoti_c_0-1770715820371.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jyoti_c_0-1770715820371.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jyoti_c_0-1770715820371.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jyoti_c_0-1770715820371.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376337iCA10853B429D1C96%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jyoti_c_0-1770715820371.png%22%20alt%3D%22jyoti_c_0-1770715820371.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ejyoti_c_0-1770715820371.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BE%8B%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%AE%9F%E8%A1%8C%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E8%A1%8C%EF%BC%88%E3%83%AD%E3%82%B0%E3%81%8B%E3%82%89%EF%BC%89%E3%80%81%3C%2FP%3E%3CP%3EC%3A%5CUsers%5Csel.mechanical.lab1%5CAppData%5CRoaming%5CMathWorks%5CMATLABAdd-Ons%5CToolboxes%5CNXP_MBDToolbox_S32K3%5CS32K3_Examples%5Cpwm%5Cs32k312_pwm_lcu_mod_carrier_s32ct%5Cs32k312_pwm_lcu_mod_carrier_s32ct_ert_rtw%26gt%3Bif%20%22~%22%22%22%20%3D%3D%20%22%22%20(%22C%3A%5CNXP%5CS32DS.3.5%5CDrivers%5CSegger%5CJLinkGDBServerCL.exe%22-if%20SWD%20-speed%20auto%20-commanderscript%20%22C%3A%5CUsers%5Csel.mechanical.lab1%5CAppData%5CRoaming%5CMathWorks%5CMATLABAdd-Ons%5CToolboxes%5CNXP_MBDToolbox_S32K3%5CS32K3_Examples%5Cpwm%5Cs32k312_pwm_lcu_mod_carrier_s32ct%5Cscript.jlink%22%20-device%20S32K312%201%26gt%3B%22C%3A%5CUsers%5Csel.mechanical.lab1%5CAppData%5CRoaming%5CMathWorks%5CMATLABAdd-Ons%5CToolboxes%5CNXP_MBDToolbox_S32K3%5CS32K3_Examples%5Cpwm%5Cs32k312_pwm_lcu_mod_carrier_s32ct%5Cprogram_board.log%22%20)%20else%20(%22C%3A%5CNXP%5CS32DS.3.5%5C%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%5CSegger%5CJLinkGDBServerCL.exe%22-if%20SWD%20-speed%20auto%20-jlinkscriptfile%20%22%22%20-commanderscript%20%22C%3A%5CUsers%5Csel.mechanical.lab1%5CAppData%5CRoaming%5CMathWorks%5CMATLABAdd-Ons%5CToolboxes%5CNXP_MBDToolbox_S32K3%5CS32K3_Examples%5Cpwm%5Cs32k312_pwm_lcu_mod_carrier_s32ct%5Cscript.jlink%22%20-device%20S32K312%201%26gt%3B%22C%3A%5CUsers%5Csel.mechanical.lab1%5CAppData%5CRoaming%5CMathWorks%5CMATLAB%E3%82%A2%E3%83%89%E3%82%AA%E3%83%B3%5C%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%5CNXP_MBDToolbox_S32K3%5CS32K3_Examples%5Cpwm%5Cs32k312_pwm_lcu_mod_carrier_s32ct%5Cprogram_board.log%22%20)%3C%2FP%3E%3CP%3E%E7%B6%99%E7%B6%9A%E7%9A%84%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E7%9B%B4%E6%8E%A5%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E3%81%A8%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81S32%20Design%20Studio%203.5%E3%81%8B%E3%82%89%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%95%E3%81%8C%E8%B6%B3%E3%82%8A%E3%81%AA%E3%81%84%E3%81%AE%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FMBDT%2Fpd-p%2FMBDT%22%20class%3D%22lia-product-mention%22%20data-product%3D%222259-1%22%20target%3D%22_blank%22%3EMBDT%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FS32K312EVB-Q172%2Fpd-p%2FS32K312EVB-Q172%22%20class%3D%22lia-product-mention%22%20data-product%3D%223493-1%22%20target%3D%22_blank%22%3ES32K312EVB-Q172%3C%2FA%3E%20%23JLINK%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2316926%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MBDT%20toolbox%20for%20generating%20and%20flashing%20an%20example%20code%20to%20S32K12%20using%20J-link.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2316926%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259746%22%20target%3D%22_blank%22%3E%40jyoti_c%20%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ES32K3%20%E5%90%91%E3%81%91%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AB%E3%81%94%E8%88%88%E5%91%B3%E3%82%92%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81J-Link%20%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%8C%E3%80%81%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E4%B8%BB%E3%81%AA%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EJ-Link%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%B1%95%E9%96%8B%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%3CSTRONG%3EJLink.exe%20%E3%81%AE%3C%2FSTRONG%3E%E5%A0%B4%E6%89%80%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81J-Link%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%B1%95%E9%96%8B%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E7%A4%BA%E3%81%99%E6%AC%A1%E3%81%AE%E8%A8%98%E4%BA%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%9A%3C%2FSPAN%3E%20%3CA%20style%3D%22font-family%3A%20inherit%3B%20background-color%3A%20%23ffffff%3B%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Model-Based-Design-Tools%2FInteracting-with-Digital-Inputs-Outputs-on-MR-CANHUBK344%2Fta-p%2F1746789%22%20target%3D%22_blank%22%3EMR-CANHUBK344%E3%81%AE%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E5%85%A5%E5%8A%9B%2F%E5%87%BA%E5%8A%9B%E3%81%A8%E3%81%AE%E3%82%84%E3%82%8A%E5%8F%96%E3%82%8A%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%89%E3%83%A9%E3%82%B4%E3%82%B9%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2321188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MBDT%20toolbox%20for%20generating%20and%20flashing%20an%20example%20code%20to%20S32K12%20using%20J-link.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F199423%22%20target%3D%22_blank%22%3E%40dragostoma%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EfreeMaster%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ES32K312%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81segger%20J-link%20%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%20PC%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9C%80%E5%88%9D%E3%81%ABfreeMaster%E3%81%A7**.pmpx%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6GO%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E7%94%BB%E5%83%8FError_FM.jpj%EF%BC%89%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%A8%AD%E5%AE%9A%E3%82%92%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82(%E7%94%BB%E5%83%8F%20freeMAster_snip.jpj)%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%8811520%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ESegger-Jlink%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20freeMaster%20%E3%83%84%E3%83%BC%E3%83%AB%E6%A7%8B%E6%88%90%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%83%9D%E3%83%86%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%A8%20ADC%20%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E8%A9%B3%E7%B4%B0%E3%81%AA%E5%8F%82%E8%80%83%E4%BE%8B%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FFREEMASTER%2Fpd-p%2FFREEMASTER%22%20class%3D%22lia-product-mention%22%20data-product%3D%222638-1%22%20target%3D%22_blank%22%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FMBDT%2Fpd-p%2FMBDT%22%20class%3D%22lia-product-mention%22%20data-product%3D%222259-1%22%20target%3D%22_blank%22%3EMBDT%3C%2FA%3E%20%23S32k312%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3CBR%20%2F%3E%E3%82%B8%E3%83%A7%E3%83%86%E3%82%A3C%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2321228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MBDT%20toolbox%20for%20generating%20and%20flashing%20an%20example%20code%20to%20S32K12%20using%20J-link.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259746%22%20target%3D%22_blank%22%3E%40jyoti_c%20%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EFreeMASTER%20%E3%81%A7%3CSTRONG%3EJ-Link%3C%2FSTRONG%3E%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E1.%3C%2FSTRONG%3E%3CSTRONG%3E%E3%83%84%E3%83%BC%E3%83%AB%3C%2FSTRONG%3E-%26gt%3B%3CSTRONG%3E%E6%8E%A5%E7%B6%9A%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20257px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20257px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20257px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377528iF64A14801026DE96%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eimage.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E2.%3C%2FSTRONG%3E%20%3CSTRONG%3E%E3%80%8C%E6%AC%A1%E3%81%B8%E3%80%8D%3C%2FSTRONG%3E%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20499px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20499px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20499px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377535i6C84EDC74B3855C4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eimage.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E3.%3C%2FSTRONG%3E%3CSTRONG%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%BE%E3%81%9F%E3%81%AF%E6%90%AD%E8%BC%89%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E6%8E%A5%E7%B6%9A%3C%2FSTRONG%3E%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20501px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20501px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20501px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377536i21DB73E8ECD68853%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eimage.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E4.%3C%2FSTRONG%3E%20%3CSTRONG%3ESegger%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%8B%E3%82%89J-Link%E3%81%BE%E3%81%9F%E3%81%AFJ-Trace%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88RTT%E3%82%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%EF%BC%89%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20501px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20501px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20501px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377537i7E82893E158FF848%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eimage.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E5.%3C%2FSTRONG%3E%3CSTRONG%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%B8%E3%81%AE%E7%9B%B4%E6%8E%A5%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%3C%2FSTRONG%3E%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20496px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20496px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20496px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377538i03B638737E66CABC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eimage.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E6.%3C%2FSTRONG%3E%20J-Link%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%8E%A5%E7%B6%9A%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%20%3CSTRONG%3E%E3%80%8C%E7%B6%9A%E3%81%8D%E3%82%92%E8%AA%AD%E3%82%80%E3%80%8D%3C%2FSTRONG%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20495px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20495px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20495px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377540i8E756806B08355FF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eimage.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377539iABF7B3781E088BDE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eimage.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E7.%3C%2FSTRONG%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AE%E6%8C%87%E7%A4%BA%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%3CSTRONG%3E%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%E3%82%92%E6%8A%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E8.%3C%2FSTRONG%3E%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%80%81%E6%8E%A5%E7%B6%9A%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E5%90%88%E6%A0%BC%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81J-Link%20%E7%B5%8C%E7%94%B1%E3%81%A7%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E7%A2%BA%E7%AB%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%83%9D%E3%83%86%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%A8%20ADC%20%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E7%A4%BA%E3%81%99%E8%A9%B3%E7%B4%B0%E3%81%AA%E4%BE%8B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CSTRONG%3Eadc%3C%2FSTRONG%3E%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%AE%E6%AC%A1%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E4%BE%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3Es32k3xx_adc_ctu_ebt%3C%2FLI%3E%0A%3CLI%3Es32k3xx_adc_single_read_s32ct%3C%2FLI%3E%0A%3CLI%3Es32k3xx_adc_stream_read_ebt%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%89%E3%83%A9%E3%82%B4%E3%82%B9%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditordragostoma_3%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2321813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MBDT%20toolbox%20for%20generating%20and%20flashing%20an%20example%20code%20to%20S32K12%20using%20J-link.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F199423%22%20target%3D%22_blank%22%3E%40dragostoma%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0%E6%AC%A1%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%201.%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%80%8CGO%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%90%8D%E3%81%8C%E3%80%8C%E6%9C%AA%E6%8C%87%E5%AE%9A%E3%80%8D%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E3%83%9D%E3%83%83%E3%83%97%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82(%E7%94%BB%E5%83%8F%20On_Go.jpj%20)%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22On_Go.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22On_Go.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377649i5D2AD98E6E63EE7E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22On_Go.jpg%22%20alt%3D%22On_Go.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EOn_Go.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E2.%20%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99S32K312%E3%80%82%EF%BC%88%E7%94%BB%E5%83%8F%20SelTarget.jpj%20%EF%BC%89%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22SelTarget.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SelTarget.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377650iB97E61C4C507E358%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22SelTarget.jpg%22%20alt%3D%22SelTarget.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESelTarget.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E3.%20%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81TestConnection%20%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%80%81%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%AE%E3%83%9D%E3%83%83%E3%83%97%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%20(%E7%94%BB%E5%83%8F%3CSPAN%3EFM_Config.jpg)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22FM_Config.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Config.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377651i6B18E16472B8293C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22FM_Config.jpg%22%20alt%3D%22FM_Config.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Config.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E4.%20%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E6%8E%A5%E7%B6%9A%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%A4%89%E6%95%B0%E3%81%AE%E5%80%A4%E3%81%AF%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E5%A0%B4%E6%89%80%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%EF%BC%88%E8%B5%A4%E8%89%B2%E3%81%AELED%E3%81%8C%E7%82%B9%E6%BB%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E8%B5%A4%E8%89%B2%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%EF%BC%89%EF%BC%88%E7%94%BB%E5%83%8F%20StoppingAtLastValue.jpj%EF%BC%89%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22StoppingAtlastValue.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22StoppingAtlastValue.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377652i0A58C0418C8D3808%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22StoppingAtlastValue.jpg%22%20alt%3D%22StoppingAtlastValue.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EStoppingAtlastValue.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%95%E3%81%8C%E9%96%93%E9%81%95%E3%81%84%E3%81%AA%E3%81%AE%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AF%20Jlink%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%20%E3%83%91%E3%82%B9%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81Readmore%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%A7%8B%E6%88%90%20GUI%20%E3%81%AB%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%EF%BC%88%E7%94%BB%E5%83%8F%20JlinkScriptPath.jpj%EF%BC%89%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JlinkScriptPath.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JlinkScriptPath.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F377653i1099CC6291C224DA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JlinkScriptPath.jpg%22%20alt%3D%22JlinkScriptPath.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJlinkScriptPath.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
