MBD Compile Error
MBD Compile Error
2,119件の閲覧回数
dmeng1
Dear Daniel:
I download a S12ZVM_Trap_Ctrl model from NXP , but when I build the model , it appears a error like belows:
could you tell me how to slove this error ? thanks very much .
1,936件の閲覧回数
constantinrazva
Hello [email protected]‌,
Please have a look here - at hotfix #2. That should fix your error.
Kind regards,
Razvan.
1,936件の閲覧回数
dmeng1
Hello Constantin:
Thank you very much , I have solve this problem. I want to ask you another question, when I generate the code from matlab simulink. How should I call codewarrior to compile the code . because generated code is C code, it is not a codewarrior project. I want to use codewarrior to compile the code and generate the elf or s19 file ,then flash it to MCU.  expect for your reply, thanks.
