How to run Simulink MBD examples in S12ZVML-MINIBRD
1,404 次查看
p_a_u_darshana
I use S12ZVML-MINIBRD to check the Simulink MBD library, and It shows a fail message when I try to build the example code. { 'CCP Communication Error. Loss Communication with CCP MCU. Please cycle power and try again." }
Do I have to install the bootloader to the S12ZVML MINIBRD first? Or Is it originally builtin in the board?
1,399 次查看
mariuslucianand
Hello @p_a_u_darshana ,
Yes, you have to flash first the bootloader on the S12 Board. You will find a dedicated chapter in the Motor_Control_Toolbox_Installation_Quick_Start Guide attached to our toolbox.
You can find the bootloaders location by typing the following command in Matlab:
winopen(fullfile(mbd_find_s12z_root, 'tools', 'BootLoader', 'RBF_Files'))
Hope this helps,
Marius
