Hi Daniel,
Recently,my team is going to design a PCB board ,the MCU of which is MPC5643L. In order to use RAppID_bootloader in the simulink,I plan to design as follows.Firstly,adding a reset swicth in the PCB board.Secondly,FAB,ABS0 and ABS2 should be configurable because the Boot Mode is SCI when FAB is one and both ABS0 and ABS2 are zero,according to the file" MPC5643LRM". Finally,configuring Pin B[2] and Pin B[2] for Serial Communication.
Is there any question in my scheme?Can you give me some suggestions?
Thanks!
HJ
