Flexcan_echo_mpc574x: What do simulink outputs on the highest level do?
afillingim
This is the flexcan_echo_mpc574x example for the MPC5744P board. The output ports in this example are at the highest level of the simulink model. What does this do in the software?
How can I use output ports at the highest level for other models?
Andrew
Daniel_Popa
Hi afillingim‌,
I'm not sure i'm getting your questions? What do you mean by:
There are no limitations on how you could use the NXP port outputs in a Simulink Model. Furthermore if you install the latest patches you could even use the NXP simulink blocks in referenced models too.
