FTM Dual Edge Capture error
990件の閲覧回数
nicolas_thory
I used a "FTM Dual edge Capture " of the NXM MBDT and after several tests tuning prescale factor It seems that there is a maximum time that can be measured by this function. Could you indicate what is this maximum? WIll a correction be possible , maybe using uint32 in output of this block instead of uint16?
タグ(1)
0 返答(返信)
