EVB doesn't work after downloading code generated by MBDT
1,350件の閲覧回数
Tkung
Hi, MBDT team,
When I use the  example model, GPIO_S32K144EVB in S32K14x MCU Simulink models, to verify MBDT function, it seems that the code had been generated correctly and been downloaded to the board, but the EVB doesn't work as expected. The reset LED kept lighting red, seems something wrong. You may find some information in following pictures and I uploaded a vedio to show the status of reset LED.
Would you kindly help me find the solution? Thank you!
0 返答(返信)
