Devkit MPC5744P rev.e data problem
2,664 次查看
haoxue1027
Now,I recevied the data which is changed from 0 to 2pi.
But I want  the value from -pi to pi.
So I set the program " if data > pi,  data = data-2*pi"
When the data <pi , the data is correct in the freemaster.
But if the data >pi , the data is big negative numbers.
Can you tell me why? how to change the data to [-pi pi]?
Any help will be appreciated.
best regards
hao
2,646 次查看
mariuslucianand
Hello @haoxue1027 ,
Have you tried to check the data type? Maybe the FreeMaster tries to display as integer and you stores in the MCU like float.
Hope this helps,
Marius
2,635 次查看
haoxue1027
@mariuslucianand hello,
I have found the reason.
Beacuse in the sincon block , the input theta is set to [-pi,pi].
But in my simulink, the input is 0 to 2pi.
Therefore, when the data is greater than pi, an abnormal data  is displayed.
best regards
hao
