Can't select different linker file - Only 192.
1,668件の閲覧回数
Poley
I am using 256KB but my the only linker options I get are 192KB.
Is it possible to change this?
Thanks!
1,496件の閲覧回数
andyknitt
I'm having this same issue with Matlab R2020a and MBDT version 4.2.0.  I am using a S32K142 but am only getting drop down options for the S32K148 linker files.  My workaround is to rename my linker file for the S32K142 to 'S32K148_192_flash.ld' and it seems to work.  However, there are times when the dialog box shows me options for the S32K142, but I can't determine a consistent pattern as to when it will show S32K142 vs. S32K148 selections.  I therefore don't have confidence that it will always use the linker script that I want when building.
I have tried updating the files provided in this thread but that does not seem to have helped:
https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/How-to-change-default-linker-script/m-p...
Is there any other way to resolve this issue?
