timer example twrk60n512 problem
2,599 次查看
dingo
I have tried to run in IAR some projects in example folder of MQX but I have problem with "timer" project . The Make was unsuccessfully, the errors messages are attached. Also you have the whole "timer" project. Previously I have configured the user_config.h with  #define MQX_USE_TIMER 1 and have updated the bsp and psp projects.
Thank you for support
2,064 次查看
dingo
Hi David,
I  have found the problem, the PSP need to be "Rebuild All " but separate not with the whole build_libs.eww. Now the timer example work OK.
Thank you,
dingo
2,064 次查看
DavidS
Hi Dingo,
I took your timer example and ran it using IAR6.10.5 and FSLMQX3.7 successfully on TWRK60N512.
Please ensure you are using IAR6.10.5 as IAR6.10.4 has compiler issues with FSLMQX3.7.
Hope this helps.
David
PS
The release notes in the /doc folder let you know what version of tools work with current MQX version.
2,065 次查看
dingo
Hi David,
Thank you,
dingo
