"No rule to make target ..... MQX-3.6.2/lib/m52259evb.cw10/mqx/intflash.lcf needed by moo.elf
1,990件の閲覧回数
dhlocker
Well, of course not, it's a source file. This is a new MQX project - all compiles fine, Eclipse/CW10 workspace is separate from MQX-3.6.2 installation directory. Looking at the makefile doesn't help - moo.elf depends on intflash.lcf and the rest of my source files. I'm feeling pretty stupid right about now - I never had this kind of trouble with hand-built makefiles, but that was a few years ago. Regards, Donald.
1,457件の閲覧回数
dhlocker
Answering my own question, in case anyone else might need the info eventually. Project->Clean and all is well.
2 返答(返信)
1,458件の閲覧回数
dhlocker
1,457件の閲覧回数
c_dawg
When using MQX, it also helps when the psp and bsp compile correctly "without errors" before compiling the project using them.
:smileyhappy:This was my obvious problem.
