Solved! Go to Solution.
Answering my own question, in case anyone else might need the info eventually. Project->Clean and all is well.
When using MQX, it also helps when the psp and bsp compile correctly "without errors" before compiling the project using them.
:smileyhappy:This was my obvious problem.
