no task to run
no task to run
1,258 次查看
ava
Hello Everyone,
I am using MK60FX512VLQ12 controller, CW10.6 & MQX4.1.
In my project I am using different task as main,usb,can,gprs,sd card & its working fine.
But recently I have observed sometimes my system get hang after restarting it works fine, then I debug the code and come to know that it goes to dispatch.s where its written no task to run and in MQX task summary status for all tasks is OK  & it is in time delay loop.
Then why I am getting no task to run?
How to solve this problem?
Please help me.
Thanks.
1,078 次查看
ivadorazinova
Dear T tech,
it could be problem with your stack size.
Please,check these threads if is not the same problem like you have
Re: MQX on custom board stuck in dispatch.s
Debug stuck in dispatch.s with MQX 4.1
If does not help, we find another solution.
Iva
1,078 次查看
ava
Hi Iva,
Thanks for your reply I will go through these post.
I am trying by modifying the stack size for the tasks.
Thanks.
