isr vs task
isr vs task
Seitec
Hi I would like ask you.
I need catch some message from I2C where is lot devices. So when message come i need separate message.  Is better way use ISR or event which is connected to flag I2C. Is possible use event?
Thank you very much
Ondra.
PetrM
Senior Contributor I
in MQX 3.8, there's an I2C slave example that shows how to continuously process messages that address your I2C device in slave mode.
The I2C driver operates on byte basis, you have to create the protocol above this low layer according to your needs in one of your tasks.
PetrM
PetrM
PetrM
