how to use the MFS shell function directly?
1,276 次查看
botaoyang
I want to creat a file in a forld in sd card, I think if i can use the shell function( int32_t  Shell_create(int32_t argc, char *argv[] )), that will be very convient for me , but I don't know  how to use these functions.
1,149 次查看
DavidS
Hi Botao,
It has been long time since I have tried this but here is a code snippet that hopefully helps you.
char_ptr   ARGV[4];
char       CMD_LINE[40]="copy d:\\SPIWeb.shtml c:\\SPIWeb.shtml";
Shell_parse_command_line(CMD_LINE, ARGV);
Shell_copy(3, ARGV);
David
