creating and compiling FFS nandflash example in mqx
2,370 次查看
adt
hello all,
I am using codewarrior 10.5 and mqx 4.0.2 & TWRK60F120M. I am able to execute the nandflash example in mqx but I want to work on nandflash using MFS I have installed patch for FFS for mqx 4.0.2. But not getting how to create and compile it in mqx.
Please help me.
2,024 次查看
LuisCasado
Check the user guide in C:\Freescale\Freescale_MQX_4_0\doc\ffs
And the demo project: C:\Freescale\Freescale_MQX_4_0\ffs\examples\mfs_nandflash
You have to build the FFS MQX library for your target and run the example.
Check the document C:\Freescale\Freescale_MQX_4_0\doc\ FSL_MQX_FFS_release_notes.pdf  "5.2. Understand MFS NAND Flash example”
Luis
2,025 次查看
LuisCasado
Luis
2,024 次查看
adt
Thanks for the reply. I have tested the example and its working fine.
