UDP Socket problem
UDP Socket problem
1,816 次查看
same
Hi everyone,
I am trying to run udp stream in my device. I wrote the below code:
addr.sin_family = AF_INET;   addr.sin_port = 10000;   addr.sin_addr.s_addr = IPADDR(192,168,1,176);   sock = socket(PF_INET, SOCK_DGRAM, 0);   result = connect(sock, &addr, sizeof(addr));
but I got this Linker error:
>Undefined : "SOCK_DGRAM_CALL"
>Referenced from "RTC_Init" in
does anyone know the solution?
regards
标记 (2)
1,637 次查看
same
Fixed.
I have forgotten that I had disabled UDP in user config file.
1,638 次查看
same
Fixed.
