UART3 interrupt in MQX4.0
2,244 次查看
utsavikalpesh
Hi all,
I am using TWR-K60D1000M and want to communicate using UART3 in interrupt mode. I am using MQX 4.0.But I am confused how to start communication.Can any one answer me????
标记 (4)
2,102 次查看
danielchen
Firstly, you need to enable uart3 interrupt in user_config.h. Then, create an ISR function for uart3 interrupt,  next, install the isr with _int_install_isr.
Please check the following link
https://community.freescale.com/thread/317094
Hope it helps
2,103 次查看
danielchen
Hope it helps
2,102 次查看
utsavikalpesh
Hi Daniel,
Thnx for reply.I have tried and it runs successfully.......:smileyblush::smileylaugh:
2,102 次查看
danielchen
My pleasure.
