TWR-MCF5225X
TWR-MCF5225X
2,208 次查看
MQXuser
I need to send emails from my 52259EVB and I see there is an example for the TWR-MCF5225X.
If the boards use the same microcontroller, why cant I use the same example for my 52259EVB?
标记 (1)
1,184 次查看
PetrM
Senior Contributor I
You can use telnet2ser_m52259evb.mcp and just replace the source files. That should be the simplest way to do it.
PetrM
1,185 次查看
PetrM
PetrM
