TWR-K60N512 + IAR + MQX example
1,574 次查看
sebasira
Senior Contributor I
Hello to you all!!
I'd like to get started with K60 MCU and MQX. I can't seem to find any code example for MQX and TWR-K60N512...I' using IAR v6.3
I've installed:
- MQX 3.8
- TWRK60N512QSDLAB.exe
Thanks!
标记 (3)
1,333 次查看
JuroV
Hello, the code examples are in mqx/examples, usb/device/examples, usb/host/examples, rtcs/examples, mfs/examples folders for MQX 3.8 installation.
1,334 次查看
JuroV
1,333 次查看
sebasira
Hi Juraj, thanks for your reply!
I've seen them, but I was use to have an IDE Workspace file that I will open with IAR... now I discover, the "Add Existing Project" option.
Thanks!!!
