Serial Port with Timeout using Timer Event
1,422 次查看
waynetaylor
Many people have asked about solutions for adding timeouts to the fgetc() blocking function. How about using a timer event to restart the task that called fgetc()? I don't know how to do it, but I think it might have something to do with _taskq_resume().
Has anyone used task queues.
Wayne
1,226 次查看
Carlos_Musich
Hi Wayne,
If you want the task to exit form fgetc() and continue you would need to modify the bsp. But if you dont have problem on restarting the task you may use a timer as you say.
In MQX installation you can find hwtimer and timer examples. C:\Freescale\Freescale_MQX_4_2\mqx\examples
You can also use lwtimer.
For restarting the task you need _task_restart()
E.g.
_task_id uart_task_id;
uart_task_id = _task_create(0, UART_TASK, 0);
_task_restart(uart_task_id, NULL, 0);
Carlos
