RTC Alarm does not work properly.
673 次查看
danielchai
Senior Contributor I
In MQX4.0.1, I use the following code to create a RTC alarm. But when it enter the rtc_alarm_interrupt, the RTC_SR is always 0x10 which seems wrong. Because it is an alarm interrupt, it should be 0x04.     Please advice.
Thank you.
void rtc_alarm_interrupt(pointer rtc_registers_ptr)
    uint_32 ui32Status = 0;
    ui32State = _rtc_get_status();
    if(ui32State & RTC_RTCISR_ALM)
    ui32Status = RTC_SR;
    _rtc_clear_requests(ui32State);
void main()
     DATE_STRUCT alarm_time_rtc;
     TIME_STRUCT alarm_time_mqx;
     if(MQX_OK != _rtc_int_install(rtc_alarm_interrupt))
             _task_block();;
      _rtc_clear_requests(RTC_RTCISR_ALM);
     if(0 == _rtc_int_enable(TRUE, RTC_RTCIENR_ALM))
             _task_block();
      _rtc_set_alarm_mqxd(&alarm_time_rtc);
    _time_to_date(&alarm_time_mqx, &alarm_time_rtc);
    alarm_time_rtc.SECOND += 30;
     for(;;);
0 回复数
