RAM requirement for USB device CDC example
Nouchi
Senior Contributor II
I would like to know how many RAM is needed by the virtual COM demo (MQX3.8.1), because it works with 32Kb (TWR-51JF), if I try 16Kb (just change ram size in lcf file), I've got an MQX_OUT_OF_MEMORY in USB_Pstn_Init.
What can I change in memory configuration to make work this demo with 16Kb CPU?
Emmanuel
DavidS
Hi Emmanual,
Please look at following document in MQX path:
C:\Freescale\Freescale MQX 3.8\mqx\examples\benchmrk\codesize\Readme.txt
Example reports are in the \results folder and viewable with Browser.
Hope this helps.
David
Nouchi
Finally, I use Freescale USB stack, which fits my needs.
bye
DavidS
Hi Emmanual,
Hope this helps.
David
