Hi Hui,
Yes! I was able to obtain the source for the flash agent firmware here:
Dropbox - TWR_WIFI_AR4100_MQX3_8_0_Patch.exe
This is going to be a very long post, but I'll try to describe in detail how I did it.
I used the source above to add the code that communicates to host.exe to my own project. This allowed me to snoop on the communications to host.exe in order to determine the information I needed to do the flashing on my own. It turns out this involves sending commands to the AR4100 that contain an address, some data and a length that tells the AR4100 to flash it's SPI memory. Once the memory is flashed, an execute command is needed that tells the AR4100 to reprogram it's firmware.
After the AR4100 is programmed, there is another command that lets you program the MAC address.
I've designed the flashing process as follows.
- When my application boots, it looks for a location in SRAM to see if it is FF (which it will be after a fresh install of your application).
- If it sees FF, it boots the AR4100 in BMI mode which is needed in order to send the commands to flash the SPI memory on the AR4100
- After booting into BMI mode, I look for the presence of a .bin file I created (attached) that is a modified version of the "flashotp.bin" file Freescale provides.
- If the .bin file exists, it proceeds to read from it and send the data it contains to the SPI memory on the AR4100 via the flash commands
- After the programming is complete, it sends the execute command
- After the execute completes, the location in SRAM is cleared and the processor is rebooted.
- After booting into normal mode, the MAC address is programmed by sending the appropriate command to the AR4100
All of the commands I'm talking about are sent using functions I had to define in RTCS.c, which I have modified to suit my needs.
Now, to handle booting into BMI mode or normal mode, modify your "initialize_networking()" function in RTCS.c to look like the following. The key things to note are lines 32-41 where I decide how to boot the AR4100, then lines 57-65 where I either setup RTCS normally, or call the "handle_wifi_flash()" function. You'll need to add the attached file entitled "atheros_wifi_init.c" to your application's source directory.
/*FUNCTION*--------------------------------------------------------------------
* Function Name : initialize_networking()
* Returned Value : void
* Comments : Sets up the TCP/IP stack, Wi-Fi device, Telnet and FTP
*END*------------------------------------------------------------------------*/
void initialize_networking(boolean mode)
int_32 error = RTCS_ERROR;
_enet_address IPCFG_default_enet_address = BSP_DEFAULT_ENET_OUI;
uint_32 IPCFG_default_enet_device = BSP_DEFAULT_ENET_DEVICE;
_ip_address IPCFG_default_ip_address = DEFAULT_IP_ADDRESS;
#if RTCS_MINIMUM_FOOTPRINT
/* runtime RTCS configuration for devices with small RAM, for others the default BSP setting is used */
_RTCSPCB_init = 4;
_RTCSPCB_grow = 2;
_RTCSPCB_max = 6;
_RTCS_msgpool_init = 4;
_RTCS_msgpool_grow = 2;
_RTCS_msgpool_max = 6;
_RTCS_socket_part_init = 4;
_RTCS_socket_part_grow = 2;
_RTCS_socket_part_max = 6;
_RTCSTASK_stacksize = 1900; // TODO: (KDC) this was 3000
_RTCSTASK_priority = 6;
#endif
error = (int_32)RTCS_create();
if (error == RTCS_OK)
if (mode == NORMAL_MODE)
// Set up the driver to boot the AR4100 normally
atheros_driver_init();
else
// Set up the driver to boot the AR4100 in BMI mode (used for programming the firmware)
atheros_driver_init_bmi();
ENET_get_mac_address(IPCFG_default_enet_device,IPCFG_default_ip_address, IPCFG_default_enet_address);
error = (int_32)ipcfg_init_device_wifi(IPCFG_default_enet_device, IPCFG_default_enet_address);
/* ENET_initialize is already called from within ipcfg_init_device. We call it again
* so that we can get a handle to the driver allowing this code to make direct driver
* calls as needed. */
error = (int_32)ENET_initialize_wifi(IPCFG_default_enet_device,IPCFG_default_enet_address,0,&handle);
if (error != ENETERR_INITIALIZED_DEVICE)
debug_printf("Failed to initialize Wi-Fi...\n");
SPIN_FOREVER;
// Set things up like you normally would here
else
// Now that we're in BMI mode and the driver is initialized, program the SPI flash for the AR4100
handle_wifi_flash();
else
{ // if the rtcs doesn't create
printf("\nRTCS_Create failed !\n");
_task_block();
This is the implementation of the handle_wifi_flash() function. I'm assuming you have an SD card to save "wifi_flash_img.bin" to - if you don't have an SD card you'll have to figure something else out.
#define AR4100_FLASH_FILENAME "wifi_flash_img.bin"
#define WIFI_FLASH_START_ADDR 0x1234
#define FLASH_BUFF_SZ 100
#define WIFI_FLASH_LOAD_ADDR 0x946E00
* Function Name : handle_wifi_flash()
* Returned Value : This function never returns.
* Comments : Programs the SPI flash memory for the AR4100
*END*-----------------------------------------------------------------*/
void handle_wifi_flash(void)
ATH_PROGRAM_FLASH_STRUCT flashMsg;
ATH_IOCTL_PARAM_STRUCT inout_param;
uint_32 error = A_ERROR;
LWGPIO_STRUCT led;
boolean led_blink = FALSE;
MQX_FILE_PTR file_handle;
char file_name[FILENAME_SIZE + 1] = MAIN_ROOT_FILE_PATH;
uint_8 buffer[FLASH_BUFF_SZ];
printf("-------- AR4100 Flash Start\n");
// Let the SD card task startup so we'll be able to access the file system
_time_delay(2000);
printf("Opening flash file on SD card ... ");
// Open image file on SD card
strncat((char *)file_name, AR4100_FLASH_FILENAME, strlen(AR4100_FLASH_FILENAME));
file_handle = fopen(file_name, "r");
if(NULL == file_handle)
printf("Could not open flash file.\n");
return;
printf("Done!\n");
printf("Sending flash commands to AR4100. The LED will blink for each command ... ");
// Set the initial address
flashMsg.load_addr = WIFI_FLASH_START_ADDR;
// Point the buffer pointer at the buffer we'll be using to read in data
flashMsg.buffer = buffer;
// Read the first <length> bytes of the image file
flashMsg.length = (A_UINT16)read(file_handle, buffer, FLASH_BUFF_SZ);
//send flash command
inout_param.cmd_id = ATH_PROGRAM_FLASH;
inout_param.data = &flashMsg;
inout_param.length = sizeof(flashMsg);
error = handle_ioctl(&inout_param);
if(A_ERROR == error)
printf("Flash command failed.\n");
_task_block();
_time_delay(10);
while(flashMsg.length == FLASH_BUFF_SZ)
// Increment the address
flashMsg.load_addr += flashMsg.length;
// Read the next <length> bytes of data from the file
//Note: Might reach the end of the file, in which case the read length will be less than the requested read length
// Set the length again in case it changed
// Send flash command
_task_block();
_time_delay(10);
// Close the file now that we're done with it
fclose(file_handle);
printf("Done!\n");
// Tell AR4100 to execute from the location we programmed.
flashMsg.load_addr = WIFI_FLASH_LOAD_ADDR;
flashMsg.length = 0;
flashMsg.result = WIFI_FLASH_OPTIONS;
flashMsg.buffer = NULL;
inout_param.cmd_id = ATH_EXECUTE_FLASH;
printf("Sending execute command to AR4100. This will take ~30 seconds to complete ... ");
printf("Execute command failed.\n");
_task_block();
printf("Done!\n");
printf("Rebooting into normal mode.\n");
// Clear the flash in SRAM here!
_time_delay(2000);
// Reset the processor here!
Then, this is how I program the MAC address once I've flashed wifi.
* Function Name : set_wifi_mac_address()
* Returned Value : A_OK if wifi MAC set successfully else ERROR CODE
* Comments : Sets the Wi-Fi MAC using the lower level Atheros API
uint_32 set_wifi_mac_address(uint_8* address)
ATH_PROGRAM_MAC_ADDR_PARAM mac_addr_struct;
uint_8 current_mac[6];
//Check to see if the value we are trying to program is already programmed.
get_wifi_mac_address(current_mac);
if (address[0] == current_mac[0] &&
address[1] == current_mac[1] &&
address[2] == current_mac[2] &&
address[3] == current_mac[3] &&
address[4] == current_mac[4] &&
address[5] == current_mac[5])
printf("MAC address already programmed.\n");
return A_OK;
else
mac_addr_struct.addr[0] = address[0];
mac_addr_struct.addr[1] = address[1];
mac_addr_struct.addr[2] = address[2];
mac_addr_struct.addr[3] = address[3];
mac_addr_struct.addr[4] = address[4];
mac_addr_struct.addr[5] = address[5];
inout_param.cmd_id = ATH_PROGRAM_MAC_ADDR;
inout_param.data = &mac_addr_struct;
inout_param.length = sizeof(mac_addr_struct);
if (is_driver_initialized() != A_OK)
return A_ERROR;
if (error == A_OK)
uint_32 read_value = SCB_AIRCR;
// Bring Wi-Fi down
set_wifi_chip_state(WIFI_DOWN);
// Wait for the AR4100 and driver to go down
_time_delay(100);
// Reset K60
read_value &= ~SCB_AIRCR_VECTKEY_MASK;
read_value |= SCB_AIRCR_VECTKEY(0x05FA);
read_value |= SCB_AIRCR_SYSRESETREQ_MASK;
_int_disable();
SCB_AIRCR = read_value;
while (1){}
return error;
You'll need these functions also - they're called within the functions I've got above.
typedef enum
WIFI_DOWN,
WIFI_UP
} Wifi_Up_Down_State_t;
* Function Name : wifi_chip_state()
* Returned Value : A_OK if wifi chip state set successfully else A_ERROR
* Comments : Special command to bring driver + wifi device up or down without
* officially shutting down the driver. This allows a task to shutdown the chip
* but prevents other tasks from having invalid enet_ptr's.
static uint_32 set_wifi_chip_state(Wifi_Up_Down_State_t desired_up_Down_state)
static LWGPIO_STRUCT wifi_chip_pwd_pin;
static boolean wifi_chip_pwd_pin__is_initialised = FALSE;
uint_32 data_val;
// initialise the WiFi chip power-down pin, once
if (wifi_chip_pwd_pin__is_initialised == FALSE)
if (lwgpio_init(&wifi_chip_pwd_pin, WIFI_CHIP_PWD__GPIO_PIN, LWGPIO_DIR_OUTPUT, LWGPIO_VALUE_NOCHANGE) == FALSE)
debug_printf("Initialising PWD GPIO as output failed.\n");
_task_block();
// switch pin functionality (MUX) to GPIO mode
lwgpio_set_functionality(&wifi_chip_pwd_pin, WIFI_CHIP_PWD__GPIO_MUX);
wifi_chip_pwd_pin__is_initialised = TRUE;
if (desired_up_Down_state == WIFI_DOWN)
// This is to prevent unhandled interrupts in the TCP/IP task
ipcfg_unbind(BSP_DEFAULT_ENET_DEVICE);
data_val = 0;
else
data_val = 1;
inout_param.cmd_id = ATH_CHIP_STATE;
inout_param.data = &data_val;
inout_param.length = sizeof(data_val);
// Send chip state command to AR4100
if (error == A_OK)
// De-assert PWD pin to keep AR4100 down. If this isn't done PWD will be floating after the driver goes down and the wifi power will cycle randomly.
lwgpio_set_value(&wifi_chip_pwd_pin, LWGPIO_VALUE_LOW);
else
// There was an error returned when we tried to send the command to the AR4100
printf("Wi-Fi chip state could not be set...\n");
return error;
* Function Name : handle_ioctl()
* Returned Value : A_OK if mode set successful else A_ERROR or A_EBUSY
* Comments : Sends a vendor specific command to the Wi-Fi device
static A_STATUS handle_ioctl(ATH_IOCTL_PARAM_STRUCT* inout_param)
A_STATUS status = A_OK;
uint_32 error = ENET_mediactl(handle, ENET_MEDIACTL_VENDOR_SPECIFIC, inout_param);
if (ENET_OK != error)
status = (error == ENETERR_INPROGRESS) ? A_EBUSY : A_ERROR;
return status;
I hope this help! I spent probably 40 or more hours trying to figure this out, so hopefully I've saved you a bunch of time.
Kyle
