Just installed KDS 2.0.0.
Following steps in "Getting Started with Freescale MQX RTOS for Kinetis SDK and Kinetis Design Studio IDE", Doc No: KSDKGSKDSUG.
Sec 2.1: Installing MQX RTOS Task Aware Debugger for GDB plug-in (TAD)
Try to access:
Freescale KDS Update Site - http://freescale.com/lgfiles/updates/Eclipse/KDS
Get error:
Unable to read repository at http://freescale.com/lgfiles/updates/Eclipse/KDS/content.jar
I have verified that this still works with KDS 1.1.0.
Does anyone have a work around for this?
已解决! 转到解答。
Hi Jeffrey,
I was able to access the update using KDS2.0.0.
But I had to only select the TAD update by itself to get it to install.
I then did re-start and re-peated the process for the Project in Project update to allow importing Working Sets.
David
Which platform are you on?
I am not able to access the update with KDS 2.0.0 (W7x86 or W7x64).
I can access the update with KDS 1.1.1.
I will try this again later from home and off of our corporate network.
Any other ideas?
Thank you for your update.
Hi Jeffrey,
I’m on W7x64.
I am assuming you updated the Eclipse first by pointing to the KSDK following path?
C:\Freescale\KSDK_1.1.0\tools\eclipse_update
The picture of my “Available Software” updates is:
NOTE: I only check on box, to the update. Restart the IDE, then do the other box. Then restart again.
David
David,
I did update eclipse as you describe. I did not get the picture of your available software updates.
From KDS_2.0.0, I keep getting the provisioning error:
Unable to read repository at http://freescale.com/lgfiles/updates/Eclipse/KDS/content.jar.
This is an ongoing problem...
I was able to install "MQX Task Aware Debugger for GDB" by making a local mirror of:
I had to use my PExDrv v10.4 eclipse install to make the local mirror copy.
**My KDS_2.0.0 exlipse install could still not get at the update site.
(I could email you an error log...)
I followed these steps to generate the command lines that got me the local mirror:
http://mcuoneclipse.com/2014/07/03/replicating-an-eclipse-update-site-for-offline-usage/
Once I got a local mirror of the updates, I was able to update KDS_2.0.0 with "MQX Task Aware Debugger for GDB".
I found a painful workaround, but not a fix...
Can confirm--I was only able to install after creating a mirror of the repo.
I found this guide very helpful: https://mcuoneclipse.com/2014/07/03/replicating-an-eclipse-update-site-for-offline-usage/
