MQX tcp send fails with socket error
915 次查看
deepaappu
I'm currently working with K66 controller and MQX5.0. I'm facing an issue with socket send. For secured periodic MQTT send, the device calls send() and fails with an error SOCKET_ERROR. Is there is way to flush the data in the TCP buffer and try again?
Deepa
标记 (1)
829 次查看
danielchen
As far as I know, only shutting down the stream socket with an abort operation can discard the socket's internal buffers immediately.
