MQX http_request.status not equal 200
1,093 次查看
r_letourneur
Hi, I'm working on a Kinetis tower K60 demo kit with an apache web app runing on sd memory. So sometimes I havn't the http_request.status == 200.
The webapp now has many folders like /css, /js, /form and I can tell that before Mqx 4.0.2 it wasn't possible to use many folders because the web pages was always incompletes
With the last Mqx version and patch 4.0.22 it's better but not totaly solved. Is this kind of error can be produced by the mqx file system or the rtcs performances?
Please could you tell me what I could modify in the BSP to try to increase the RTCS or filesystem performances?
997 次查看
Luis_Garabo
Hi Regis,
There is not enough information to make a judgment of what could be wrong. What is your application requesting to be waiting for a OK? MQX supports these requests:
HTTPSRV_REQ_GET
HTTPSRV_REQ_POST
HTTPSRV_REQ_HEAD
If the OK is not being returned then what is the web server answering?
Garabo
